GX Head or Not?
What do you fella's think?
GX Head for Sale
The manifold water cooling holes threw me off, as did the manifold stud bolt pattern looks more H89-ish to me. Anyone got a good eye for the head face to determine the oiling hole or whatever? I'm having a mental blank and I've forgotten what to look for
Posted on: 2010/10/31 3:14
Re: GX Head or Not?
From gold coast QLD australia
A real GX head should have Nissan cast in the top and should have single studs between the inlet ports(well mine does).GREG
Posted on: 2010/10/31 3:21
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
Re: GX Head or Not?
Sandblasted too?......Yikes
Posted on: 2010/10/31 3:29
Re: GX Head or Not?
From Coondle, WA Australia
Rebuilt Nissan/Datsun 1200GX Cylinder Head. Full profesional race port, big valves, angle milled, big springs ect. Some very minor nicks in no 3 chamber from previous ring land failure, has been crack/pressure tested. Was on weber fed speedway engine.
spose its not bad value really if the work described is tru even if its not a "gx" head.
but by the time yu add postage, maybe not.
Posted on: 2010/10/31 22:37
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: GX Head or Not?
From Christchurch NZ
GX heads have four water galleries, which are a little bit larger than the H89 ones.
Posted on: 2010/11/1 7:46
Forced Induction!
Re: GX Head or Not?
From sydney.nsw
NOT,i asked the question. reply was h89 601 casting.
Posted on: 2010/11/1 12:14
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: GX Head or Not?
Yeah righto, another muddled 'GX' identity.
Posted on: 2010/11/3 14:03
