fwiw they used to run single 1 3/4 SUs on drawthrough holdens. they were definitely restrictive in that guise, but in all seriousness, a single 1 3/4 should be enough for practically any boost level you'll be likely to try on an a series - even an a15. People have managed about 220bhp from a single SU in drawthrough (defiitely that much in blowthrough) but the combo producing that much power in a drawthrough would probably jump 20-30 bhp just from a less restrictive carb at the same boost level.
But for an A series 1.5 litres, a single SU is enough. The 'trick' that happens when comparing carb size - i.e. 2 of them on a 1.8 litre motor - well if you actually separate each intake event, you'll see that with cams around std duration, there's very little overlap of each intake even on a 4cylinder, so a single SU feeding all 4 would still do the same as twin SUs split up that only feed 1/2 and 3/4. For each of those carbs, about 50% of the time, they are 'technically' not flowing all the time. Whereas with the turbo, it's flowing through the carb all the time.
Another example of this is comparing carb flow on an inline 6. believe it or not, the sort of carb cfm you'd need to feed a twin carbed six (with 123 fed by one carb and 456 fed by a second) would actually be the same sizing Per carb, as if you ran a single carb (or carb throat) on each individual cylinder. Since on there's no real intake overlap of those cylinders..Not that too many people bother looking at it that way, since there's other advantages of one carb throat per cylinder in NA setups.
Anyway point being - 1 3/4 will do the job, for sure. Not that anyone here (afaik) is trying this, but hypothetically if anyone wanted to run methanol, you can actually fairly easily adapt a holley fuel bowl and float (and they have off the shelf needle and seats that flow enough for alcohol, made specfically for them in fact) to cope with the amount of flow rate that an SU fuel bowl/needle and seat would struggle with. If anyone wants I'll do a few diagrams of it.
Posted on: 2010/11/3 5:39
