Browsing this Thread:
1 Anonymous Users
Universal Joints!! |
My Uni joint on the tail shaft is phucked As I understand they are pressed from factory on the utes and I require a whole new tailshaft! Is their an alternative such as machining a replacement on or am I left to cut and shut the tailshaft using a replaceble uni (bluebird yolk and flange)??
Posted on: 2001/6/18 3:12
Re: Universal Joints!! |
Not too shy to talk
a restaked universal joint can be milled out at amachinist shop and replaced for around $110 aus but as standard they are pretty weak,,, i got quoted $500 for a totally new tailshaft that can handle 350 hp ,,, didnt have $500 SO MINE STILL CLICKS EVERY TIME I TAKE OFF :( buzzard cya
Posted on: 2001/6/18 6:43
From Tassie, Australia
Both of mine were shot when I went for rego, so luckily they replaced the worst one only and it past rego inspection. The cost was $135 for one (thats why I didnt get two done, ie front and rear). They must break them appart or something because mine has four or so tack welds to hold it back together. Sounds dodgy but I have never had a problem!
Posted on: 2001/6/18 8:20
