« 1 (2)
Re: B310 front struts+VL calipers, which rotor?
From Ballarat Victoria
The sheds an hour away these days so i`ll get some Pn`s on Sunday when im there.
Posted on: 2010/11/18 6:38
Not too shy to talk
check out this mate will answer all your questions!!!
http://ozdat.com/forum/viewtopic.php?f=31&t=14878
i did this on some sunny struts instead of 180b!!
Posted on: 2010/11/18 6:56
From Taupo New Zealand
what I did Bart-
vn calipers, open the holes out slightly to suit the bigger datsun bolts.
u12 bluebird vented discs, I think 254mm dia. 20mm wide and about 1.5mm from memory removed from the mounting face to give correct offset
mount the struts on opposite sides so caliper is at front otherwise they limited steering lock too much
all this is from memory, did it years ago so details a bit hazy...
Posted on: 2010/11/19 9:53
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Christchurch NZ
Has that disc over hub, or disc behind the hub morgan? (that bluey stuff aint worth much these days)
I had been led to believe that the only difference between trubo and no was the cooling fins. (dunno where I got that idea)
VL turbo's are rare as here. (Never seen one, but I met a bloke who reckoned he had one) So that might not be an easy opion after all...................
Posted on: 2010/11/19 10:01
Edited by A14force on 2010/11/19 20:46:13
Forced Induction!
From Perth
VL turbo and VL V8 use the same calipers as VN-VP V8 or 6 cyl with FE2 suspension
Also the same as all VR-VS regardless of engine
And no you can't use a VL caliper with a solid disc and expect the pads to stay in there long
When they get too thin they will flick out of the caliper
Posted on: 2010/11/19 10:54
Thanks mate.
Yeah I didn't think solids would work. All the commodore sh1t is quite foriegn to me.
Posted on: 2010/11/19 20:44
Forced Induction!
disc bolts to back of hub as original. also had to drill disc to bolt to hub, easy. I think I might have used 510 hubs now from memory, which are almost identical to 310 hubs except offset of disc mounting is different. So yeah check for yourself that it will work as I did it quite a while ago, dont want to put you crook.
I used new Lucas discs from Repco to suit u12 bluebird at a cost of about $30 ea.
Posted on: 2010/11/20 7:06
1970 1200 coupe A15
1978 B310 SR16VE
Thanks Morgan.
Posted on: 2010/11/20 7:42
Forced Induction!
« 1 (2)
