« 1 (2) 3 »
Re: R31 Diff questions
From Geelong, Vic
mine had a bit of a whine when i first made it, but i just replaced all lthe centre bearings and it was fine
the fact that it is getting rather hot is a bit of an issue though. is there anywhere on the diff that it is hotter than other spots? around certain bearings or something?
Posted on: 2010/11/24 22:51
From Brisbane
Your problem is: oil, adjustment or wear - in that order.
If it's to the point where it's that loud & it's getting hot, either way it's stuffed and you should fit a new set of gears to it.
Posted on: 2010/11/25 1:36
From Mandurah, Western Australia
Done a bit of a ring around today. For new bearings and reset of the tollerances its going to cost be about 500.
One joint wants to drop new crown and pinion into it, but they want $900 just for the new gears. Then another 500 for bearings and setup.
The other shops were prepared to use another crown wheel and pinion if I could find a good one (assuming mines stuffed). There is a heap on Ebay, but will have to do a bit of research as these are $200 and you can get another diff for that sort of $$$.
They all said sounds like pinion bearing wear which has confirmed my suspissions.
Posted on: 2010/11/25 6:51
Here's my thoughts
Pull the diff out and send it up to Diff shop and get them to have a look. Dont want to stuff up the axles I have just had splined. Unlikely I know
If they come back and say pinion and crown is stuffed might do the looking around for good 2nd hand one one and look at buying lsd center for it. Are the $200 commodore ones on Ebay the go?
Thoughts
I am at the point where I am commited to staying with this setup having had custom tailshaft done, custom handbrake cables, shortened housing and having axle re-splined.
Posted on: 2010/11/25 12:17
From Perth
You had the housing shortened , axles done.... and you never checked out the 400 ooo km old centre ??????????????????/
Posted on: 2010/11/25 14:31
Niel at the end of the day the diff was cheap and I was fully aware that it may need a re-build. For $50 for the diff and $150 for axle mods I am pretty well infront of a comparable maddat setup.
Even if I throw $600 at it, it is still a reasonably cheap diff setup. But will probally look at dropping a Commodore LSD unit into it as opposed to the open center. Can drop back to 3.5 or 4.1 gears as these are way cheaper than 3.89 ones.
Posted on: 2010/11/25 23:39
From Brisbane
Posted on: 2010/11/26 4:16
From Perth
I wasn;t knocking your choice of diff
I have the same one waiting to get cut down for my own car
Plus 2 x 4.11 gearsets , a mini spool and a 4 pinion LSD
I was just curious as to why you would do all that work and not check the centre after so many kms
And who shortened the housing and axles ?
Posted on: 2010/11/26 10:28
Pulled the diff out of a R31 that was been wrecked in the quokka and after 2 hours of battling to get it out. Checked the odometer on the car. 400,000 was a bit of a shock.
As not able to hear it running, I did pull the back off clean it out and visually look at the gears. no chipped teeth, no burring on the teeth, not sharp on leading edge so figured it was worth a shot.
I have done all the housing mods and then had Final drive machine axles to suit.
To the accuracy of my equipment the housing is true, but the diff shop I am thinking of using is going to check, but reckon that the symptoms I have are due to pinion wear.
As 3.89 gears are NLA new goin to drop 3.7 gears into it if my crown and pinion are at the end of there life.
If I can source a good LSD center they will fit this in preferance to an open center, but 2nd hand they are about 150-250 so struggling to justify the money on a street car that is driven once a month.
Posted on: 2010/11/26 11:37
From Perth
http://cgi.ebay.com.au/4-Pinion-28-sp ... ories&hash=item4cf3423e4b
Thats who I got my LSD centre from
WA Diffs wanted blood money for anything I wanted
So I took my diffs back and never went back
According to my diff breakdown... these are the parts
Try to use Timkin bearings... and supply yourself and save :)
DKF03 Suits :- Borg-Warner Late Ford / Nissan
Components Part Number Quantity Description
Front Pinion SET 309 1 M86649 / M86610
Rear Pinion SET 67 1 HM88649 / M88610
Carrier Bearings SET 69 2 LM501349 / LM501314
Spacer TP4662A 1
Gasket ARC6DZ4036A 1 51517
Oil Seal 402516N 1 165.262.37 104
Posted on: 2010/11/26 12:29
« 1 (2) 3 »
