A12 Turbo using stock exhaust manifold.
From Mandurah WA
Curious.... im not after a full on street monster but, WOULD it be possible to make a adaptor to fit a turbo of the end of the stock exhaust manifold ?
Has anyone else thought of this before ?
Posted on: 2004/1/15 15:56
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: A12 Turbo using stock exhaust manifold.
From Christchurch NZ
I havent tried it yet but i belive it can be done. Dependingon turbo size it could flange straight on. It would be easyer on an
early type 1200 because the mount is further forward giving more clearence
Posted on: 2004/1/15 18:17
Forced Induction!
From Brisbane, Australia
it's not uncommon. Just a right angle or 'J' pipe off the bottom of the cast iron exh manifold to the turbo. but keep it as short as possible, and it would be a good idea to make up a bracket to help support the weight.
Posted on: 2004/1/15 22:38
From newcastle, NSW
The turbo setup that i have uses a stock exhaust manifold off a A15(sunny i think) without a hot box(pollution gear)a peice of pipe between 2 flanges, the top flange is where the turbo bolts on,pretty easy really!
i'm not going to use that, instead as L18 B110 pointed out i'm going to make a "J-pipe" i would assume that a j-pipe woud be better.
Are you doing or thinking about a turbo setup?
Posted on: 2004/1/16 7:02
From Melbourne, Australia
i have two pics in my recieved files of what you are thinking of, but its quite possible it was steveo who sent em to me, ill post em on the site anyway
Posted on: 2004/1/16 7:08
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Posted on: 2004/1/16 7:12
1200 Coupe Rallycar
ahhh
i've had those pics for ages and i've finally just figured out whats going on with the inlet.
there is a flange bolted to the stock inlet, it has a pipe standind vertically up on it which would have a hose connected to it on a "suck-through" setup
i dont think this is really that bad-a-design, quite simple, not much fabrication required
and as i found making my manifold there is always gonna be sharp turns in any exhaust system unless you get super fancy, and then you just run out of room anyway
Posted on: 2004/1/16 7:15
1200 Coupe Rallycar
The boys are on to it.
The exhaust of a A15 with a 'j' made out of plumers steam pipe bends works very well and does'nt require any bracing as it is inherently very strong, similar to what 1200 rc has posted, a bit shorter. All flanges can then be profile cut from a decent thickness plate steel and mig welded to the steam pipe.
Posted on: 2004/1/16 8:11
From newcastle, NSW
heres a picture of mine[img]http://datsun1200.com/modules/myalbum/photo.php?lid+2647[/img]
thats a good idea using the standard inlet manifold instead of using a plenum(i think thats what its called)
i might look into that
Posted on: 2004/1/16 8:45
From newcastle, NSW
Posted on: 2004/1/16 9:14
