Master Cylinder
From Snohomish, WA USA
Anyone know the bore size and stroke length for the 1200 sedan? I need a new one and Wilwood has some aftermarket ones. 3/4" to 1". I'm thinking a 7/8" will work fine. I have not yet pulled my old one out.
Link to Jegs and Wilwood master cylinder.
Wilwood Master Cylinder
Posted on: 2010/12/25 19:17
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: Master Cylinder
From Christchurch NZ
I dunno the stroke, but the standard 1200 M/C is 11/16. I wouldn't advise going bigger unless you're running some pretty big brakes. Otherwise you'll need a booster. I just run the standard 1200 M/C with my S13 front brakes, and the pedal feel is awesome.
Posted on: 2010/12/25 20:50
Forced Induction!
Re: Master Cylinder
I have standard disc brakes in the front but 320 truck drum brakes in the back. So 11/16 is smaller than the Wilwood 3/4 bore so maybe the 3/4 would work for my brake setup? The 7/8 would be to much?
Posted on: 2010/12/25 22:39
'73 2 Door Sedan
Re: Master Cylinder
Standard m/c in USA is 11/16 for disc brakes.
You can use a B310 cylinder it 13/16. This increases pedal effort, but reduces pedal travel for a "tighter" feel.Brake master cylinder
Just drill two holes to fit it or use the booster adapter.
Posted on: 2010/12/25 23:43
Re: Master Cylinder
Im just going to go with the Wilwood 3/4. Should work fine. Thanks.
Posted on: 2010/12/26 3:02
'73 2 Door Sedan
