« 1 2 3 (4)
Re: Which thrust bearing carrier? (60a 5speed into 120y)
From Wellington
fully back off the adjustment at the firewall the clutch pedal goes to the floor and seems have no effect - ie Can't shift with motor running and it feels softer than it should.
If I fully tighten up the adjusting nut the clutch pedal has very little movement but still seems to have no effect. what movement there is feels soft.
Can anyone tell me what the symptoms are of a thrust bearing carrier too long, and a thrust bearing carrier too short?
Above is cable to loose and then to tight, it needs to be set somewhere in the middle
Posted on: 2011/1/20 8:18
Anyone know what cars the long thrust bearing carrier came out on?
Posted on: 2011/1/20 11:02
A bit more info...
The reason tightening the cable did not help is because the fork seems to hit the end of the slot on the casing of the gearbox before the clutch disengages. That's what is stopping the pedal - the fork hitting the gearbox.
I'm also now suspecting the clutch pressure plate as the culprit. It's the only thing that has changed in the setup apart from the gearbox. I emailed the seller to ask for dimensions and he said the "unsprung height" was 38mm. My old plate has a height of 40.5mm.
This is the kit I bought.
http://cgi.ebay.com.au/ws/eBayISAPI.d ... geName=ADME:X:RTQ:AU:1123
Posted on: 2011/1/21 9:18
From sydney australia
The problem is your clutch fork. the 60 series boxes need a clutch fork with an L shaped end. If you've used the standard fork, it'll do what you're experiencing. The difference is because the 'bellhousing' length is longer on the bigger boxes. Hopefully you've got this style fork with the box but didnt use it. I know you can buy the longer throwout bearing housing from Pitroad or BProject, but I don't know about buying the clutch fork. I'm putting a 5 speed in my Sunny, I have access to the correct housing & clutch fork, but I'd have to replace them when the owner of these parts needs them, so if anybody can get a part number for the clutch fork with the l shaped head, I'll just go email Bprojects to see what if they're available.
Posted on: 2011/1/21 9:50
Thanks I hope you're right. I have the other fork. :)
Posted on: 2011/1/21 9:52
Seriously, been there, made that mistake, got the scars to prove it, & the nightmares . It'll cure the problem, & if it doesn't, can I buy it off you?
Posted on: 2011/1/21 10:20
For RHD B310 with cable clutch (from japan-market catalog)
* 30531-H7410 LEVER-WITHDRAWAL [60-series, F4 and F5]
* 30531-H1000 LEVER-WITHDRAWAL [56-series]
Bearing is the same for all, including L-series and A-series engines
* 30502-21000 BEARING-CLUTCH RELEASE
Bearing collar differs
* 30501-H5000 SLEEVE-CLUTCH RELEASE [56-series]
* 30501-H7500 SLEEVE-CLUTCH RELEASE [60-series, A14/A15 engines]
* 30501-H8560 SLEEVE-CLUTCH RELEASE [60-series, A12/A13 engines]
Posted on: 2011/1/23 2:07
The 5 speed fork fixed it. All good now.
Posted on: 2011/1/26 9:16
« 1 2 3 (4)
