« 1 ... 6 7 8 (9) 10 »
Re: s/charged a14
from my own experience in blow through turbo applications, it is needed for the standard carbie to be boxed or completely sealed, this is because the gaskets on the carbie blow out under boost. This happens around 12 psi boost.
Posted on: 2004/1/22 1:00
Re: s/charged a14
From Millgrove Vic OZ
The small supercharger is the SC12. The larger is the SC14 from the 1GGZZ???
Posted on: 2004/1/26 6:20
Cheers Feral
Re: s/charged a14
From Melbourne, Australia
yeah thats right feral, the 1JGZE i think it is called
Posted on: 2004/1/26 8:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: s/charged a14
From campbelltown (sydney) australia
the 2 litre supra s/c is off the 1g-gze engine im going to be using this same supercharger for my a15
Posted on: 2004/1/26 10:30
Re: s/charged a14
From South East QLD
The Toyota Superchargers ...Dont make much power above 5500rpm no matter what you try ,,Due to being inefficient at hi rpm due to high air temperature output and power consumption . But the low to mid range is great due to instant torque .. this makes a great engine to drive on the street due to a wide torque band .. you make about 100hp at the wheels with this efi/ supercharger setup on a A15. .
Running a Carby can be touchy so you cant make as much HP "safely" due to not being able to fine tune the fuel and ignition maps easily .. The carbys should always be sucked by the super charger ,,as super chargers are positve displacement .. Running blow through box carby would most likey crush the floats when the throttle is closed as well .... Sorry if i sound negative ,, but just trying to save you some money and time ..A Super charged "A "series is still worth doing if you do it the right way ...
Posted on: 2004/1/26 11:43
Re: s/charged a14
Point of order.
"SOME" superchargers are positive displacement.
Paxton & Latham are just two who make superchargers that are of the centrifugal & axial flow variety.
The superchargers used on Merlin, Griffin, Wright, Pratt & Whitney, Daimler Benz, & Junkers aero engines are all of the centrifugal type
Generally speaking, "supercharger" refers to a mechanicly driven air pump as used on an internal combustion engine [also rotaries] while the "turbo" name is generally used to describe an exhaust gas powered turbine, driving a centrifugal air pump [or supercharger] Turbo Supercharger is a correct term that is normally reduced to "turbo" for simplicity.
Posted on: 2004/1/26 12:04
Love your Datsun.
Treat it well.
Re: s/charged a14
From Christchurch NZ
Anyone who is considering supercharging , or if you love a good read I strongly recomend A do-it-yourself guide to street super charging
by SA DESIGN (car tech) . I just borrowed it off a mate, and although itlends more towards V8s and "jimmy huffas" its still a brilliant source of valuble information.
Posted on: 2004/1/28 5:39
Forced Induction!
Re: s/charged a14
From Gold Coast Aust
All of these posts leave me to wonder how the hell I got my wagon to run/work/start or even fire it's all to much for me to understand and I mean that
I just did it and it worked stuffed if I know why.
I am not being smart in any way But ask those that have seen the car and ridin in it
So stop wondering how to just do it
Posted on: 2004/1/28 11:11
Datsun 1200
Keepin' the past in the future
Re: s/charged a14
u cant just build it without money so while ur gathering funds its much better to gather info at the same time then u dont stuff it up, when ur runnin a pretty big blower considering engine size, if u stuff it up. it can go wrong real badly.
Posted on: 2004/1/28 11:19
Re: s/charged a14
From GOLD COAST AUZ
Yer just do it. WALLY DID
Posted on: 2004/1/28 11:23
rather be a old fart than a young d##khead
