fuel problem
From Goulburn NSW
Hi guys and girls went to go for a drive in my ute coughs and splatters even back fires through the carby had a friend look at the carby and he said that its not getting fuel, poored some down the carby went like it should do is it the fuel pump?
Posted on: 2011/2/19 9:03
Re: fuel problem
From Secret Harbour WA
hey mate if i was you i would start out simple like check the fuel filters then try the pump...by the way what sort of pump is it??? electric or just the one driven off the engine??? could be dirty could be an issue with the power supply to the pump if electric... possible but might not be the issue but it could be your float in your carby as it is not filling it up with enough fuel... just a few things to check out i could be wrong... but worth a look at..
Posted on: 2011/2/19 9:11
Re: fuel problem
From Goulburn NSW
checked the filter checked the fuel lines havent checked the pump do i take the line running to the carby off and kick it over see whether or not the pump is pumping
Posted on: 2011/2/19 9:37
Re: fuel problem
give that a go any it will tell you if your getting fuel or not check to see if it serg's cause that could mean your pump is on its way out...
Posted on: 2011/2/19 10:54
Re: fuel problem
From Albany, Perth Australia
try this....if there isnt fuel in the filter use and air blower down the fuel line to the tank and see if it comes out, then put the filter back on. Take the fuel line off where it attaches to the carby and get your mate to crank it over and see if it comes out the hose. If it doesnt then there is probably a blockage some where if it does then there is something blocking the carby. this is where you chuck the air blower through the carby to blow it out and hopefully dislodge the stuff out
Posted on: 2011/2/19 11:00
1200 Smerf Mobile
Re: fuel problem
From mandurah
i wouldnt put compressed air into the carby ,cos it might damage the needle and seat of the fuel bowl arm
ide do all of the above and pull the top of the carby and check the needle and seat for a block by (blowing with your mouth) blowing through the fuel inlet pipe on the carby and if the air wont pass through then its blocked in the carby
hope this helps ,kinda mixed messages ,but all of the above should be helpful somehow
Posted on: 2011/2/19 11:14
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: fuel problem
agree with estyre, use low pressure in the carb.
Posted on: 2011/2/19 20:30
Re: fuel problem
From Goulburn NSW
hi guys checked the fuel pump pumping fine checked all the lines fine so would i be wright to say its a dirty carby i did get told when i bought it that the carby needed a clean its also had a flat spot when accelerating which again means carby
Posted on: 2011/2/20 1:33
Re: fuel problem
clean that sucker
Posted on: 2011/2/20 3:00
Re: fuel problem
From mandurah
they are a realy simple carby ,so just buy a new gasket/rebuild kit for it then ,pull it down and clean every single part ,and ide pull the jets out one by one and clean them and then put them back in there correct spot cos some they are different sizes
and it wouldnt hurt to use carby cleaner in when cleaning jets and stuff ,when i did my twins it worked a treat ,gets rid of any carbon and cleans the ally up real nice !
good luck
Posted on: 2011/2/20 6:57
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
