(1) 2 3 4 »
wtd- Stanza struts and lca's urgently !
From Gold Coast
I need some good condition stanza struts and lower control arms, dont have to have any brakes or calipers as i already have these.. preferably in nsw, can get them picked up if any Melb ppl have them.
reply here or pm, call/sms 0406143946
Wardy
Posted on: 2011/2/22 2:21
Re: wtd- Stanza struts and lca's urgently !
From MOOROODUC. Victoria
Ok there's a STANZA - almost complete as of 4 weeks ago at a wreckers in Dandenong (SE Melbourne). Don't know the year or other details other than he was willing to part with the complete struts for $220.
Call Japwreck 03 9798 7166
Posted on: 2011/2/22 2:38
From Geelong, Vic
dont limit yourself to stanza, 200b and most 240k are the same as far as you are concerned
Posted on: 2011/2/22 3:24
From Gold Coast
Ah righto I thought that. Just wasn't sure. Do they all run the same size stub axle and caliper bolt spacings? The brake kit I got is to suit a stanza strut that's all. Cheers for the heads up demarcoz! I'll give them a buzz and see what they say.
Posted on: 2011/2/22 3:35
From Sydney,NSW
Is a 200B LCA the same length and size as a stanza?
I thought 200B Stub axles were slightly bigger.. Might be wrong though
Wardy, try Stewart Wilkins Motorsport, He might have some..
Posted on: 2011/2/22 6:26
From Gold Coast
yeh im not too sure chooie, i wanna make sure my brakes will fit before i buy some struts lol.. i might give stew wilkins a call too and see what he has. id rather not spend a small fortune if i can help it.
Posted on: 2011/2/22 8:21
My 200b Brakes fit straight on to my stanza struts - same stub axle, same mounts. Not sure if all models are the same.
Posted on: 2011/2/22 9:10
im using stnza struts with 200b hubs and brakes no issue. had done the same reversed previously (stanza brakes on 200b struts)
Posted on: 2011/2/22 9:24
From Gold Coast
hmm ok then cheers for the info boys.. i may have some struts on a 200b out at the farm so i best check!
If not ill be still on the lookout for some.
the top hats and springs need to be changed to the smaller type tho dont they? And ill still have to use stanza lca's.
Posted on: 2011/2/22 10:13
From Melbourne, Australia
Hey Wardy, I got a set of Stanza struts off Japwreck (who one of the guys recommended earlier) just the other day. I'm pretty sure he said he had another set so if you get stuck you should be right with them.
Posted on: 2011/2/22 10:38
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
(1) 2 3 4 »
