« 1 (2) 3 4 5 ... 7 »
Re: meet 'Francis" the one owner 1200 sedan
From Kyoto Japan
just an update.
Surgery on Francis has started, because of the delicate nature of Francis(high miles) and Terrys' worry about the insides, I've called in an expert, "Dr Mark"(race engine builder and tuner(Qual eng reconditioner 15yrs, and mechanic)and I will be assisting(I'm only a mechanic), with Dr Mark's record for last year(average engine build last year produced 399.4 rwhp) Terry aggreed Mark the right man for the job.
I started the by removing the very dirty heart(reminded me of working old trucks....DIRTY).Engine out, no problems. Removed clutch and Flywheel(2nd clutch for francis ..still asbestos type)clutch at 40-59% worn(will be reused). mounted onto a stand and started the delicate surgery..
Carby - 2.5 mm of shaft play(not sure now how francis even ran with that size vacuum leak), will need replacement.
Inlet man. Just dirty.
Exhaust man. bottom bolts came off like they were ust put on. hot box flap 3mm of play will need to be removed and holes plugged and manifold HPC coated(black)
First complication!
removing head bolts 3 were finger tight!! 2 snapped at the head, all others undid normally. One head bolt although undone wouldn't come out of the head.
Terry started to get worried when Francis wouldn't let the head come away from the block.... Emergency procedures were bought into play (brass drift) and after 20 mins the head finally came away.
with the head off it quickly became obvious that francis had a blown head gasket no2(clean piston). inspection of head revealed blown head gasket also (just) on no4 and a badly burnt ex valve on no4.
I
Posted on: 2011/2/26 11:36
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT!
Hayashi Racing
Secret Factory Japan
From Kyoto Japan
Pulled down the rest of the motor.
Dr Mark bought down some of his specialist surgical equipment.
Time for a measure up.
now just bear in mind Francis has over 455000kms on this bottom end.
measured all bores
worst #4 over sized by 0.0045"
will need to be bored 0.020" unless someone can sell me some cheap new 0.010" pistons and rings
measure big ends
worst #1 0.0005" under.
will need 0.010" larger bearings
measured main bearings
all ok!!!
pics soon
Posted on: 2011/2/26 11:56
Hayashi Racing
Quite a regular
From Sydney NSW
Amazing how was it even running? The short block still sounds good too even after such high mileage/death march tuning. Just goes to show, if you blow one of these it's because you screwed up the build.
Posted on: 2011/2/26 13:53
Quite a regular
ABSOLUTELY!
And thats why mine is going back to bog stock!! (well.. maybe not exactly..)
Zordmaker
Posted on: 2011/2/27 10:45
From Perth WA AUS
Great build thread, love it :)
Posted on: 2011/2/27 11:56
Datsun 1200 2Dr sedan.
From mandurah
thats amazing ,i cant believ the bottom end is so good for the kms its done !
great build ,its even got clear visors too :D
granny spec !
Posted on: 2011/2/27 12:49
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Kyoto Japan
some pics of the engine
Posted on: 2011/2/28 9:27
Hayashi Racing
From Kyoto Japan
head bolts
head stuck
head off
#4 burnt valve
Posted on: 2011/2/28 9:46
Hayashi Racing
Yikes those valve seats are hammered. Many miles on them ...
Posted on: 2011/2/28 9:56
From Kyoto Japan
top ring is a bit worn
[img
width=500]http://i971.photobucket.com/albums/ae193/SanitoraOtaku/francis/DSC_0827.jpg[/img]
how did this work??
note the broken head bolt
Posted on: 2011/2/28 10:15
Hayashi Racing
