« 1 ... 15 16 17 (18) 19 20 21 22 »
Re: datski's 1200 sedan V1.2
new welder? or just new wire? i knew you axed the ozito.
looks ok
Posted on: 2011/3/1 8:50
From Perth WA AUS
I lent the weldcorp to Datski & Beiber and it was not working properly after that, so I took it back to bunnings and got a new one. Not bad for an self taught amatuer with a cheap gasless :)
Posted on: 2011/3/1 9:29
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
well it was working ok on low with the .8 i had in, it wasnt till i changed it to the .9 it started to do stupid stuff. and as for the welder mine is better but there was contaminants on it from the stupid gasless welder but i know my weld will hold as im sure your one will too now
also i have just bolted the gearbox in properly and is completely mounted as well as putting the extractors on and the carby....starting to look like a car again :o)
Posted on: 2011/3/1 11:23
1200 Smerf Mobile
From mandurah
pfft i seen brett weld that with his work welder ! and when you welded it ,it just fell off when you moved it hahaha
nice work brett ,shouldnt be long till the engine bay is done !
how did you go with the clutch lined up properly ? make any difference when bolting it up ?
Posted on: 2011/3/1 12:16
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
yeah was easy to put on...there was nothing wrong with the work welder just someone fiddling with the gass pressure...bloody bieber bastard!
Posted on: 2011/3/1 12:24
1200 Smerf Mobile
From Perth WA AUS
Bieber!
Posted on: 2011/3/1 12:42
From mandurah
damn it to hell ! i am not beiber ,i am murphy !
murphy, murphy, murphy ,ooooooohhhhhhhhh
Posted on: 2011/3/1 15:02
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
well finished bolting the exhaust and carby on and wrapped the extractors
Posted on: 2011/3/2 10:39
1200 Smerf Mobile
From Secret Harbour WA
the engine bay is looking nice an clean and tidy....
good work on the wrapping too... its time consumin
you build is coming alone nicely
Posted on: 2011/3/2 11:01
brinty murphy maybe estyre... oh snap- thats not whoring
car looks great brett, you worried about the wrap making the extractors rust out over the long term? apparently the retain air woisture once cooled and can cause cracking and rusting out of the metal underneath.
Posted on: 2011/3/2 11:28
