Vent Holes doesn't drain water down properly ?
From Sri Lanka
Hi Guys
Look at this pic the water falling through this vent holes
are gathered under it and and from where they are falling down ? any hole inside it to drain water,
i have noticed while driving in the rain and when car rear is upper than behind i am getting water falling to the driving cabin , so i guess water falling into it is gathered in without draining out
any one has any idea how the setup under this vent holes
THANKS
REGARDS
SUMITH
jpg  DSC00080.JPG (65.69 KB)
10994_4d7072a20079b.jpg 640X480 px
Posted on: 2011/3/4 5:03
Re: Vent Holes doesn't drain water down properly ?
The water exits out the side of the car (in the Datsun 1200, i suspect the B210 is the same).
So clean out the passageway and all will be good
Posted on: 2011/3/4 5:52
From RAdelaide
like so....
jpg  sumith.jpg (39.59 KB)
12659_4d7081375a4f9.jpg 500X375 px
Posted on: 2011/3/4 6:05
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From Sri Lanka
Hi DD
thanks, but the area is clean except few rust
yes But there is hole from this area towards to the car drive cabin from that area only the water comes in, there should be a way this water should go out of this i guess ?
is there any hole inside this area for water to go down ?
Hi srb210
your explanation is not clear for me can you detail it a please
thanks
regards
sumit
Posted on: 2011/3/4 6:40
It is common for rust to put a hole in the dash. Then the water comes into the car.
Posted on: 2011/3/4 6:46
From Sri Lanka
Hi DD
Actualy those holes look made not because of the rust , don't you have that type of one in yours in both sides, i wanted to know whether that is from factory or something unigue to my one or earlier tinkering guy has made them
thanks
regards
sumith
Posted on: 2011/3/4 7:17
From Perth WA AUS
Maybe try to find some rubber grommets to seal the holes if its not a rust hole.
Posted on: 2011/3/4 8:37
Datsun 1200 2Dr sedan.
From RAdelaide
I'll get some pics tonight. There's no other holes other than fan draw and what rust has made. Pics shortly
Posted on: 2011/3/4 8:39
Edited by srb210 on 2011/3/4 10:03:16
From RAdelaide
First pic shows entry point on passenger side under bonnet hinge ( rectangle hole) , second shows exit point in inner guard ( rectangle hole). The highest point in the middle is where blower vent takes in fresh air. Its has a rolled curve to keep water out, the only way that will let in water is if these two holes in front of each "a" pillar are seriously blocked or if you have rust holes in surface of cowl drain
hope that helps
png  P1020055_1.PNG (65.46 KB)
12659_4d70c3b5b8cec.png 202X151 px
png  P1020052.png (61.54 KB)
12659_4d70c433c91d3.png 151X201 px
Posted on: 2011/3/4 10:54
Not too shy to talk
From Portland Oregon
This is a link to how the drain system is constructed, hope it helps http://community.ratsun.net/topic/19381-cowl-drain-holes/
Posted on: 2011/3/4 14:55
