« 1 ... 4 5 6 (7) 8 »
Re: 68 2dr 1000 sedan jdm build
From Brisbane
http://cgi.ebay.com/ebaymotors/ws/eBa ... &sspagename=STRK:MEWNX:IT
won these today so its a bit of a start for the engine side of things
Posted on: 2011/2/21 7:24
From Brisbane
change of heart now im going to try to build a fuel injected turbo a10 aslong as i canget it engineered in qld :)
Posted on: 2011/2/25 9:01
From Brisbane
just wondering what tyre size should i run?
theres plenty of room at the back but not much at the front, guards are going to be flared also
Posted on: 2011/3/5 0:47
From Rosewood, QLD
tasty quad carbs would love them for my A12
Posted on: 2011/3/5 1:01
1971 B110 sedan project.
2012 Nissan Micra daily.
From Brisbane
yeah keep an eye out on international ebay theyre pretty cheap just need to get a manifold made to suit. found some nice tyres 195 45 14s on ebay aswell apparently they arent being made in australia anymore lowest profile i could find was 60
Posted on: 2011/3/6 2:08
From Brisbane
My bike carbs arrived today can't wait to get this thing going
Posted on: 2011/3/9 11:12
I found in the past the quad carbs prefer long runners for street engines.
For bikes revving over 12,000rpm is a different story.
Especially since A10 engines lack so much torque down low the longer the
runners the better for a 59mm stroked road going engine.
I have a design I made in case I did it again for a 1000 which clears the
bonnet, gives heaps more torque and look beaut with a personally engraved
plenum with perspex top exposing the shiny trumpets or velo stacks.
The oil filler will need to be moved to the front on the rocker cover and
it will still clear the dizzie using double L or right angled tipped leads.
Rocker cover and top section is welded together as carbs unbolt easily and
will allow tappet adjustment being removable from lower inlet halve.
The idea is from another 1200 member in the past that turboed the same kind
of manifold on an a12 round port and made 100+hp at wheels and had heaps
of tractable torque and less lag.
jpg  quadtorquer.jpg (102.50 KB)
737_4d77fdf8af535.jpg 2342X1724 px
Posted on: 2011/3/9 22:21
From PORTUGAL
Hi jarrydsNIZ12
Try one of this : Works as an Extra Air Supply also Ralenti is Great ( rubber pipe on right goes to engine breath hole near the clutch .
( I took the idea from 2 stroke Yamaha DT 50cc Carby that has a pipe going to a plastic box under the gas tank ).
jpg  5221.jpg (56.82 KB)
3647_4d7801f4dd3a1.jpg 578X433 px
Posted on: 2011/3/9 22:41
Edited by FAZPIOES on 2011/3/9 23:06:50
Edited by FAZPIOES on 2011/3/9 23:07:41
The Worst it Looks - Bigger The Challenge ...
From Brisbane
well i changed my mind yet again today and went and bought the efi and extractror setup off of myb110. So now im going with a fuel injected a15. will be looking for an a15 in the coming weeks if anyone in brisbane/ gold coast has one theyre getting rid of.
Posted on: 2011/4/9 2:34
Didn't think those extractors would fit, nice one.
Posted on: 2011/4/9 2:43
