« 1 (2) 3 »
Re: Early or Late Model Engine
From sydney australia
You've got to get the correct fuel pump as using the early one in a late model means the arm doesn't engage with the cam eccentric & it won't pump fuel. Putting a late pump in an early engine works until the arm breaks & the fuel stops pumping. So you do need to be careful about what pump you get. The arms are peened in, so you can't easily change them, or I'd have a large L series fuel pump attached to both my Sunny's. I seem to remember some metal balls in behind the peening that added to the fun.
For the blank off plate, any Series 2 Bluebird will have a plate you can use right at the front of the engine on the alternator side, as they have a facet electric pump at the back of the car( why don't you see if it's still there, it's inside that metal shield between the fuel tank & the rear axle).
Posted on: 2011/3/10 9:39
From Sydney, NSW
Thanks so much b310gx..
just wondering where in syd would i find a late model pump?
Goss make a pump but for some reason it spans all the year ranges so im thinking that can't be correct!!
anywhere you can think of?
I contacted auto 1 and they said the only pump they have is a fuelmieser that suits 1971-1980?? so how would that suit the early and late model engines?? I'm most confused!
Cheers,
Tom
Posted on: 2011/3/10 22:00
Edited by thomen on 2011/3/11 3:06:30
Where can i buy late model fuel pump?
From Sydney, NSW
Cheers,
Tom
Posted on: 2011/3/11 3:09
From Sydney, NSW
from the forum wiki
Re: A-series Fuel Pump Comparo
Top left: late-A12 original style,5 bolt top
Top right: triangular top mid-1970s
Bottom left: early A12 (short arm), 1-bolt top
Bottom right: non-rebuildable circa 1980
and the one I bought:
[img]http://i.ebayimg.com/24/!B-ld(2!!2k~$(KGrHqYOKioEzWlY7myDBM9EWvBYHg~~_12.JPG[/img]
mine doesn't look much like the early model pump yet the ebay auction said 1970-1973
Posted on: 2011/3/11 4:36
Re: Where can i buy late model fuel pump?
Just about anywhere: supercheap, repco, Nissan dealer, ebay.
Like this one from ebay. Although you can't tell from the photo if it is for early A12 or late A12.
jpg  fuel_pump.jpg (28.47 KB)
174_4d79c10c0616f.jpg 500X375 px
Posted on: 2011/3/11 6:28
From Sydney, NSW
hahah that's the one I bought...
I don't know if it's early or late.. they say 1970-1973
but the end of it doesn't look like an early one..
i asked at auto one and they said the only part numbers they had were for a fuel pump spanning 1970-1980..
which could be either any
Posted on: 2011/3/11 6:35
Where it looks the same or not doesn't matter, see if the arm is the same and the dimensions are correct.
Don't forget that there is a phenolic spacer too.
Posted on: 2011/3/11 11:06
Have you actually tested the output of the pump?
You're going to be really annoyed with yourself if you buy a new pump only to find that a partially blocked filter was the cause of your problems all along.
Replace the filter first [cheap & easy] then see if the problem remains.
Posted on: 2011/3/12 8:18
Love your Datsun.
Treat it well.
From Sydney, NSW
But is the filer inside the pump or in the carby? I have an inline filter that i did replace.
Posted on: 2011/3/13 22:12
Get a hold of an engine or repair manual and go from there or pick up a spanner and have a look, you sound fairly cluey get some practical into the mix and you will find the solution to the problem will come quicker.
Posted on: 2011/3/13 22:30
« 1 (2) 3 »
