What Year Was This Engine Made?
Quite a regular
From Olympia, WA, USA
I have an A12 Ser # A12 526504. Its an early front distributor 1200. In checking the numbers, it was made earlier than my '72. Could it be an early '71? I'm still trying to figure out if it's a closed chamber head.
Here's what I know... It came out of a b210 (not original as engine mounts are homemade). It has a 310 electronic distributor (matchbox on side).
Posted on: 2011/3/29 16:03
Edited by Ron1200 on 2011/3/29 20:12:43
"Horsepower... May you always have enough"
Re: What Year Was This Engine Made?
Quite a regular
Maybe we can make this a bit more fun...
Please chime in with your '71 engine serial number. Let's see who has the oldest one!
Posted on: 2011/3/30 15:41
Even if the engine number is a 1971, if it was rebuilt, the 1972 head is a direct replacement, so you won't know for sure. They are both the same compression (heads). The piston dish varies to give different ratios.
I think the 500xxx numbers are JDM engines. They sold a ton of 'good used japan engines' during the 80s. In that case it is likely to have the closed chamber head.
Remember, the closed chamber head is good for 1 HP over the open chamber in the A12. The difference is not as much as in american engines or in the later A14/A15 engines, but it's still enough to make a difference.
Posted on: 2011/3/31 7:51
Mine are 72s and in the 6xxxxx numbers
Posted on: 2011/3/31 8:03
From Sri Lanka
Hi Guys
Mine is 73 Made,engine no range 53XXXX
thanks
regards
sumith
Posted on: 2011/3/31 9:57
Re: What Year Was This Engine Made? Who has the Earliest Ser #
Quite a regular
Pulled the engine # from the engine in my 72 coupe and it's A12-114754. However according to the VIN plate it should be A12-171172. So obviously it's not the original engine.
So far I have the earliest engine in my 1200. Can anyone beat a 114754?
Didn't think of the 'Crate Motor' possibility DD, but that makes perfect sense.
Posted on: 2011/4/2 18:29
