« 1 2 3 (4)
Re: CAMBER TOPS!!!
From Melbourne, Australia
Whatever it is it's gunna pull up!
Posted on: 2011/4/9 11:09
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Re: CAMBER TOPS!!!
From mandurah
I used vs commo caliper which bolt onto the 180b struts and I then bought a set of new magna verada rotors (296mm) ,which then jarrad (oldskool) machined the inside rotor hole out to slide over the back of the 180b hub .next the 4 holes were drilled in the rotor to suit the hub
Then I chopped and welded the strut 75mm to suit a nissan pulsar (n10) strut insert , so its now 3 inch shorter than factory and will allow for heaps of travel with nigels car dumped on its bum !
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: CAMBER TOPS!!!
We're digressing a bit here but I'm trying to make VT Commodore (396mm rotors)brakes fit to Stanza struts. It's looking pretty tricky but I've cut down the back of the Commodore hub, machined the centre out of the hub out so it slides over the top of the Stanza hub which now needs to be machined back the same thickness as the hub plate of the Commodore so it's spaced in the right spot. I then need to drill holes and tap threads into the Commodore hub plate to bolt it to the Stanza hub where the disc formerly bolted on. God that sounds confusing! I'll be sure to post the results in my build page once I get stuck into it properly.
Now back on topic!
Posted on: 2011/4/9 11:23
Current Fleet-
Re: CAMBER TOPS!!!
From Sydney, Australia
I use 180B (large axle) strut, 260z (sports) rated inserts and 250 pound, 225mm freelength springs with helper springs (All springs from Kings)
200pds were bottoming out on most Sydney roads. Probably ok for track with the right shocks.
Posted on: 2011/4/9 12:39
Re: CAMBER TOPS!!!
From mandurah
Wow thays a hell of alot of work for brakes !
Posted on: 2011/4/9 13:09
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Re: CAMBER TOPS!!!
From Brisbane
I just use standard 1200 struts, longer lca's, s13 ca brakes, otomoto sleeve kit 4kg, chopped 3inch with mk1 golf inserts with 1 inch spacers, bump steers. Only strut needs to be threaded after being chopped and strut top nut re-threaded to suit inserts as the piston shaft is larger.
i used this setup because i thought it was the easiest, parts availability, sufficient to my needs and handles the weight of the sr20 well. otomoto 4Kg springs with helper springs, the front end is pretty stiff with plenty of camber, maddat sr20 swayer. handles so well like it has powersteering which makes it so fun to drive doing hill climbs.
im afraid using bigger struts and brakes may put off the offset too much and can't run 7.5 wheels.
Posted on: 2011/4/9 13:16
Re: CAMBER TOPS!!!
From A-TOWN
Inkjunkie thats pretty much the same setup im going for but running 120Y struts, do you have a pic of your car? wouldnt mind seeing how it sits.
Also what LCAs did you run?
Posted on: 2011/4/10 6:46
« 1 2 3 (4)
