conversion questions
Quite a regular
From cootamundra.. NSW
in the process of doing engine conversion and having some troubles:
1) i have fitted an a series 5 speed and to do this you have to remove the reverse switch, my question is- do you have to put something back in the hole where the switch came out of? i cant seem to find a small enough bolt to fit in it.
2) the accelerator cable is to short and repco dont have anything to suit the a14gx with twin su carbies. please help me
Posted on: 2004/2/2 7:08
Re: conversion questions
From Melbourne, Australia
yeah pretty sure you have to plug the hole, i ground down a bigger bolt and used it for mine
Posted on: 2004/2/2 7:14
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Disabling the reverse light function in a registered car is a defectable item, & i didn't have any problems with the reverse light switch in my 1000 with 5 speed. These have a small tunnel, but i also have the small trans, so this might be the diference.
If this is a road car, then surely there must be a way to keep it. If it's a racer, use a cut down big bolt.
Posted on: 2004/2/2 10:41
Love your Datsun.
Treat it well.
From Newscastle, Australia
Hey Dodgeman...even if it is a racer, CAMS still require all lights to be working as intended in most racing categories.
Posted on: 2004/2/2 11:38
Just goes to show ya, i'm strictly street.
The only racing i did was at Westmead speedway in the 60's [it's now Westmead hospital] & a few runs down Castlereagh dragway in the early 70's [it's now a housing or industrial development i believe] Neither of these required lights.
Posted on: 2004/2/2 11:50
Love your Datsun.
Treat it well.
From Sydney, Australia
Westmead speedway! I've lived in Sydney all of my life and never even heard of that!! Thanks for the history! I remember Liverpool Speedway.. The night smell of nitrobenzine certainly turned me into a petrol head.
I don't remember much before 1978....
Just means that you were in your prime through the 60s and 70s..that makes me envious.
Cheers,
Chris
Posted on: 2004/2/2 13:10
Westmead teaching hospital was built on the site of the former Parramatta Showgriund. The Speedway was located within the showgrounds & the last season was in 1967. It was a banner year.
We raced a 1934 Dodge, Model KCD sedan & did OK with one feature race win to out credit. I still have my 1967 Club member keyring with it's enamel membership tag.
It was fun.
Posted on: 2004/2/3 22:06
Love your Datsun.
Treat it well.
From Wellington New Zealand
The switch body can be shortened, find an understanding fitter and turner. From memory you can remove 10mm, and lightly dress the tunnel where the switch is. (That means hit it with a hammer) As for the throttle cable go to a motorcycle repair shop and have them make you a cable they are not expensive.
Posted on: 2004/2/3 22:56
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
