« 1 (2)
Re: 180b wagon diff into KB10 - H190 Axles anyone got any?
From mandurah
I had 12s on my r31 diff in my coupe haha
But yes 13s clear the brakes ,my jellies fit so your wheels should ben
Posted on: 2011/4/14 12:59
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth Western Australia
Cheers for the info fellas!,
Jesse, cheers for the borgy, still might take you up on it might try for the H165 first.
Sounds good rubes, the R31 will be my backup if this H165 proves too stressfull to make happen
Ok so i have two questions then!
1. What model bluey did the H165 come out in? or if they know of one about.
I have quokka and gumtree at hand ready to spring on one once i know the model.
Failing that
2. Does anyone have a R31 diff they would like to sell, or know of where one is i can procure for my coupe?
I've got it stuck in my brain to use the H165, dunno why it just appeals to me more than the R31 option but at this point i'm ready to whack anything in...almost
Posted on: 2011/4/15 2:21
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
Re: H165 from blueburd into KB10 - need a bluey housing!
From gold coast QLD.
I get mine from series 1&2 wagons the series 3 has the 190
Posted on: 2011/4/15 2:31
From Darwin NT
nissan vannete? maybe the h165 axles might be able to fit im trying this soon
Posted on: 2011/4/15 6:08
current project 4x4 patrol...
I pulled a Vanette to bits 12 months or so ago mainly for the diff centre and a few other bits.It was an early model with the 1200 motor 4 on the tree and H165 rear end.What i found once removing the axles was,totally differant brakes,backing plates and fittings etc.massive bearings(compared to the 165 ute)and also slightly wider axles but don't remember how much,so as a result after removing the pumpkin and the other stuff i wanted i shoved the ales back in so i could move it and took it down to sims metal to get some cash back.
Hope this helps.Cheers
Posted on: 2011/4/15 6:38
Ok so i think this is the right model series one bluebird wagon
Yeeeehhhhaaaaaaa!
Posted on: 2011/4/15 6:39
Datsun 1000 it's
All-round Action!
Not sure,i think the series 3 has the wrap around bumpers like the photo.To be sure other than looking underneath the 1 and 2 series have an L series engine and the 3 has a CA
Posted on: 2011/4/15 6:43
ok cool, off on scouting missions this weekend!
Posted on: 2011/4/15 7:31
Datsun 1000 it's
All-round Action!
« 1 (2)
