« 1 ... 3 4 5 (6)
Re: Getting rid of the front leaf springs on a 1000
From Geelong, Vic
for gaz stuff contact the guy at Corby motorsports. he sends stuff to australia a fair bit and was really helpful when i was talking to him
what measurements do you need? i can measure my ones for you.
but yeah like i was saying, the downside with gaz is that their product information is crap
Posted on: 2011/4/21 0:01
The sizes would be as LJ has mentioned for the qa1 setup
shock -
10.75in extended
7.9in collapsed
spring -
8in long
1.875in diameter
150lb rated
this is the Jp setup
[img width=400](script removed)CaricaFoto("http://www.risebike.com/pro/GAZO_LOGO ... ion/Yahoo%20012.jpg");[/img]
However looking at this site they could prob get it for 100aud cheaper
Maybe I should get Gav to go there with his spare shock? as it could be closer to him?
http://www.minisport.com.au/prod1880.htm
Posted on: 2011/4/21 2:24
Would you be able to measure the diameter of your setup pigdog? The shock and the spring Id. I was just talkin to the guys from minisport and they don't even have a spec sheet they just go off the comprssed and extended lengths so the only thing I'd be worried about Is the diameter
Posted on: 2011/4/21 3:53
Im thinking if I get that stocky from Gav I can go into my motorbike haunts
and get the best affordable billet coil over setup. I bought some from Thailand
a few years ago from a Honda cruiser replacement and are seriously strong and well
built for $50 a pair. It went into a lotus caterham copy functioning perfectly.
Will try to find some pics.
Posted on: 2011/4/21 5:16
thats cheap, well im ordering the qa1 setup i'll let you know how it goes i've gotta make up new bottom mounts (hopefully can get them cnc machined) and get the correct rod ends so will be a bit of work
Posted on: 2011/4/21 6:08
« 1 ... 3 4 5 (6)
