How to Avoid RustT From Newly Welded Pannels
From Sri Lanka
hI gUYS
How to Avoid Rusts From Newly Welded Pannels'what should i apply on it first. someone proposed me NO LEAK is it advisable ?
thanks
regards
sumith
Posted on: 2011/4/25 9:37
Re: How to Avoid RustT From Newly Welded Pannels
use primer paint
Posted on: 2011/4/25 9:52
id be going with 2pac primer, im using it, seems to work well.
Posted on: 2011/4/25 9:53
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
etch primer mate
Posted on: 2011/4/25 9:56
datsun a15 ute
sorry i meant etch primer also :S
Posted on: 2011/4/25 10:12
1200 Ute - Mild A12
Quite a regular
From Sydney, Australia
Weld thru primer, single pack. Get it from paint supply shops. Use it on the back of stuff being welded.
Posted on: 2011/4/30 3:48
If your talking about protecting the metal before you do the welding then go for a 'Weld through primer' or 'Cold Gal' as both can be successfully welded on. With normal paints you will have major issues trying to weld over them (a lot of spitting and weld spatter).
Posted on: 2011/4/30 7:33
