(1) 2 3 4 ... 7 »
oda70 build ca+1200ute
From Brisbane
Hey guys, ive learnt alot from these forums so heres my build. My build started about year and half ago. I will try and edit the thread as i think of things ive missed.
History:
datsun 1200 1979 Metallic pearl blue
worked a12 built/flat top pistons,large cams twin 38s. Bare metal body respray.
I am the third owner bought it off mike and i think he owned it for 1 year.
old plates were AF41TI and mike put on the oda70 - datto ones
Bought car from mike 9/12/06
fun part, parts list
Maddat ca fitting kit
Maddat race coilovers
re-built front end
r31 diff 3.9 min LSD dr datto supplied kazz 2way waiting to be fitted
ca gearbox - serviced
remote clutch kit maddat
short shifter kit
Turbosmart BOV plumb back
Turbosmart 1200 fuel reg
ca cm flywheel
garrett gt2871r + gtx35082 trial rear
Quick Spool manifold
600x300 intercooler pwr
A.R.E custom radiator and external pump
fuel pump 044 x2
70lt fuel tank foam filled
Haltech 2000s
haltech IQ3 Display Dash
ENGINE:
ACL race b/e
acl race m/b
cp pistons
spool conrods/fasters
arp main studs
arp head studs
acl/cometic head gasket
tomei poncams 260
ross balancer single version
full gasket set
ca race springs
cpc custom plenum
tomei adjustable cam gears
CDI
8x 1000cc
ok pictures
starting to remove old engine
http://i1181.photobucket.com/albums/x438/Tieslow/P1050700.jpg
http://i1181.photobucket.com/albums/x438/Tieslow/P1050706.jpg
old engine out
http://i1181.photobucket.com/albums/x438/Tieslow/P1050720.jpg
rebuilt ca18det, bought from forum member - later found out motor was #OOPS#ed bores worn (oversized) and crank cracked.
http://i1181.photobucket.com/albums/x438/Tieslow/P1050694.jpg
Posted on: 2011/5/8 1:41
Edited by oda70 on 2011/5/8 2:29:38
Edited by oda70 on 2011/5/8 2:48:50
Edited by oda70 on 2011/7/9 3:30:03
Edited by oda70 on 2014/11/15 2:16:04
Edited by oda70 on 2014/11/28 22:36:34
Re: oda70 build ca+1200ute
From Brisbane
Moved car to workshop to fit engine into car.
http://i1181.photobucket.com/albums/x438/Tieslow/P1050744.jpg
http://i1181.photobucket.com/albums/x438/Tieslow/P1050749.jpg
got my new cooler/radiator wanted everything to be behind grill.
http://i1181.photobucket.com/albums/x438/Tieslow/P1050654.jpg
http://i1181.photobucket.com/albums/x438/Tieslow/P1050650.jpg
fuel tank fitted, used the stock service panel hole for lines to run through. Tank is mounted back from cabin for weight position.
http://i1181.photobucket.com/albums/x438/Tieslow/IMG_0181-1.jpg
engine bay shot after new motor fitted (new block and crank + piston/rods/cams) custom cpc intake running 8 injectors
http://i1181.photobucket.com/albums/x438/Tieslow/IMG_0618.jpg
Posted on: 2011/5/8 3:10
looks good, so is dr datto still going?
Posted on: 2011/5/8 3:13
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Brisbane
oil cooler behind front apron :) sexy
http://i1181.photobucket.com/albums/x438/Tieslow/IMG_0614.jpg
maddat tunnel fitted/ gearbox xmember. short shifter and nissan boot covers, car bit dirty :(
http://i1181.photobucket.com/albums/x438/Tieslow/DSC00755.jpg
car as of now, next to other datsuns at dr's workshop
http://i1181.photobucket.com/albums/x438/Tieslow/DSC00757.jpg
Posted on: 2011/5/8 3:21
From Brisbane
dr datto is only doing part time car work now (busy with other things atm) has moved workshop 2 times. My car is been moved to new workshop on tuesday to finish off car.
Posted on: 2011/5/8 3:27
From mandurah
Great work ! With that motor it will be a handfull !
Keep them pics coming
Posted on: 2011/5/8 4:20
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Nice looking build, ca18det and 1200 ute match made in Australian Heaven.
Dr Datto has a 1600 ute wowsers
Posted on: 2011/5/8 5:00
From Brisbane
Car is now at new workshop Monro racecars :)which is alot closer to home. Got my rims from Frkyca, thanks mate. Waiting on parts from maddat ( heater box, heavy duty clutch pedal).
Just recieved my 2871 external gated housing t31 v-band looks sexy. Going to be fitting a compound turbo setup later down the track.
2871 feeds a 3582 :) picture says a 1000 works
http://i1181.photobucket.com/albums/x ... %20setups/December008.jpg
http://i1181.photobucket.com/albums/x ... 0227-1246167701_thumb.jpg
Posted on: 2011/5/11 8:03
From sydney
No worries :)
Just looking at your tread , your ute is going to be an animal.
Posted on: 2011/5/11 8:22
PROJECT:DATSUN sunny sedan CA18det
From Gold Coast
Wow that's a pretty full on spec list! I'm keen to watch this develop. Compound setup will be very unique when running. Good stuff mate
Posted on: 2011/5/11 8:46
(1) 2 3 4 ... 7 »
