a15 auto choke carby on a12 engine??
From vic
hi i was wandering if i can put a A15 auto choke carby on a a12 engine that had manual choke?
would it run properly with the jetting it comes with? the one i want is the one in the link!
http://www.alibaba.com/product-gs/231 ... 5_CARBURETOR_PART_NO.html
thanks!
Posted on: 2011/5/8 10:54
Re: a15 auto choke carby on a12 engine??
Yes, it will work fine. That's what I'm running. It is jetted leaner than the original carburetor is all.
Minimum order of 100 units on Alibaba.
Posted on: 2011/5/8 17:48
From vic
hi i couldn't reply because my computer was broken! so any ways im getting this carby in the link for $150 delivered and was wandering how to wire up the autochoke! its manual (ATM) (A12 motor!)
also could you confirm if this one will fit i don't want to order the wrong thing!
also how ddgonzal said its a bit leaner will this improve performance or decrease it if so how much by??? any affect on acceleration??
http://www.aliexpress.com/product-gs/ ... SSAN-A15-wholesalers.html
Thanks sorry for all questions just dont want to buy wrong thing!
Posted on: 2011/5/11 12:52
They also sell a brand-new A12 carburetor. Why not buy the 'right' one?
Posted on: 2011/5/12 3:06
From vic
hi thanks i would buy the a12 one but wanted it with auto choke and the a15 carby is the only one with it on the website!
if you think it will run fine a bit lean i will buy it or else i wont. i found these specs on tech wiki for a12 and a15 carbs in comprarioson their similar jets (ithink) besides the slow air bleed looks like a huge difference?
would it run good??
http://datsun1200.com/modules/mediawi ... Carburetor_Specifications
thanks!
Posted on: 2011/5/12 8:33
As i said, it will work fine. That's what I'm running: A15 carburetor on a Datsun 1200 with A12 engine.
Posted on: 2011/5/12 8:48
From vic
ok thanks one more question for the auto choke i have heard that i can connect it to the 12v+ side of the ignition coil!
sound rite??
thanks!
Posted on: 2011/5/12 8:51
I have done so and it works.
The factory wiring is a bit better, is uses a relay trigged by alternator output. That way if you turn the key on for a bit before you start it, nothing happens. See Choke.
Posted on: 2011/5/12 9:00
