Browsing this Thread:
1 Anonymous Users
Re: Silvia-Specr's Project Sleepy |
From Vancouver, Wa
got the new driveline, looks great, installed and it fits good too, next too finish up the rear brakes.
Posted on: 2011/5/15 7:19
1969 Datsun 1000 (B10) 1972 Datsun 1200 coupe (ADVAN) 1981 Datsun 210(B310) 4-door (sr20det) 1971 Datsun 1200 (sedan)
From Vancouver, Wa
figured i would add some more pics, new driveline in, progress on the rear brakes and h165, i get the new calipers tomorrow, the front rack and pinion all in, the hot side of the intercooler piping in, the cold side almost done, tucking the wires for the front light out thru the fender(guard). and the finished shift tower.
Posted on: 2011/5/16 7:35
From Vancouver, Wa
Well i got the new rear calipers the other day, and got them installed, put on the right front caliper tonite and bled the brakes, also bled the clutch. waiting on some hardware to come in for the adjustable tension rods. next to drop the tank to install a 5/16 fuel tube, fans for the radiator, install the alum coolant overflow tank, more wiring, fuel pump, battery in the trunk, more wiring. i'm getting tired already.
Posted on: 2011/5/21 6:30
Registered Users Contentmaster Usermaster
nice work
is that a stock S110 rear axle with disk brakes?
Posted on: 2011/5/21 6:57
From Vancouver, Wa
brakes are now working, clutch is working to got the e-brake adjusted,took the front tension rod bracket and cut out center bigger and made it bolt up like the s13, so i installed the s13 adjustable tension rod, and then playing around i put on some 19" wheels on the front, started removing the fuel tank, and called it a day.
Posted on: 2011/5/23 6:33
From Vancouver, Wa
Thanx DD, yes that is one out of a 1980 200sx, H165, with disk brakes, the calipers were shot had ot buy new ones, $70 each, but they work good now. I gotta remember to bring home some battery cable from work for the battery in the trunk.
Posted on: 2011/5/23 6:37
From malta
gr8 job buddy - i m really impressed by the job you've done
Posted on: 2011/5/23 20:49
From Vancouver, Wa
finally got a nice enough day to roll the car out and take some more pics. was playing around and grabbed the 19 x 9.5 rear wheel to try it on and it just fits without rubbing, couldn't believe it.
Posted on: 2011/6/1 5:56
Looks goodĄ
Posted on: 2011/6/1 7:57
From malta
i like the idea of the black frame near the windows and the spoiler fits gr8 in there :) car looks really clean but devilish inside
Posted on: 2011/6/5 13:43
