Thermo Fan
From Sydney, NSW
Hi Guys,
just wondering what size thermo fan would suit.. I want to remove the stock fan on my a12 as it's hitting my radiator on certain angles (datsun conversion in a morris.. common prob)
would a single 8" davies craig do the business or should I go for slightly larger.. 10" fans won't fit or 2 8" fans?
like this?
Cheers,
Tom
Posted on: 2011/5/29 15:35
Re: Thermo Fan
From Seattle ,WA.
a 10" fan will fit on the stock 1200 rad, this is whats on mine - fine the highest CFM you can get...
http://www.the-fan-man.com/shop/size- ... -0360-p-187.html?cPath=33
Posted on: 2011/5/29 16:23
Re: Thermo Fan
From Sydney, NSW
I have a morris minor running the engine so clearance with a 10" fan between it and the grille is an issue.. would an 8 inch fan provide sufficient cooling?
Cheers,
Tom
Posted on: 2011/5/30 3:27
Re: Thermo Fan
From Coondle, WA Australia
Thats a bit hard to say really.
I would suspect so. I was gonna run 2 x 5" fans on my thou at one stage, and a 8" single fan would probally have more surface area to drag thru the air then the 2 x 5" units i have.
And a 8" fan would be bigger then the std 1200 plastic fan with out a shroud.
Posted on: 2011/5/30 4:16
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: Thermo Fan
From Ringwood, Melbourne, AUS
from what I recall in another thread you had a pretty large radiator didn't you? That would give you a bit more cooling capacity when moving so I would think that the only thing you need to worry about is when sitting still etc.. However, I have only run 10" on mine so can't say if 8" will be enough sorry..
Posted on: 2011/5/30 4:17
Deano
Re: Thermo Fan
From Sydney, NSW
I might run a single 8" fan off to one side and if i need more cooling I'll throw another 8" fan on the radiator..
Thanks guys!
Posted on: 2011/5/30 4:45
