a12 turbo for sale
From ipswich
a12 turbo $1000, everythin u see in this pik
a14 head rebuilt, reground seats new valves (better than standard) and resurfaced, new rings and bearings, honed bore, tighe cam, crane electronic ignition and custom distributor, custom turbo setup, heavy duty clutch and 4 speed gear box
Posted on: 2011/6/2 1:22
datsun 1200 ute
* turbo A-series * mandarin mica paint * flare kitted and air dam front bar
xh ford falcon longreach s pack 302ci
rolls on 4 big round things
Re: a12 turbo for sale
From Freo
good score..Bonus toolbox, some shelves, Oils, Old Skool welding helmet, engine stand... ha ha...
Bump...
Posted on: 2011/6/2 2:57
A15 PSI Project Motor
'72 CB750k,
From mandurah
Bargain ,motor sounds like a winner ,is it tuned ?
Posted on: 2011/6/2 3:49
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From ipswich
haha well not quite everything. motor isnt tuned, the carby is over fueling n very difficult to adjust so probs could do with a better su or similar. water pump has a leak and not sure if the fuel pump is workin as i had it gravity fed last time it was running
Posted on: 2011/6/2 4:14
datsun 1200 ute
From Townsville, Qld
that'd be pretty cool if you built a engine dynomerter like Sykine is doing but use tailshafts and a sliding frame to accomdoate different motors\gearbox combos to give a closer output to correct drivetrain loss.
Also nice setup, consider parting out everything passenger side of the manifold studs?
Posted on: 2011/6/2 5:54
From ipswich
also it work in another way that u could build a motor that could then bolt stright into the dato engine bay if u were to use standard mouting points but change the engine/ gear box mounts. also wouldnt be hard to set up a load to really test the engine before installing. just the stand alone is worth a few dollars but i just want to sell the whole package as is also not really keen on seperating the turbo setup i payed a 1000 alone just for that so as it is this is a good deal and im really not asking for much
Posted on: 2011/6/2 8:04
datsun 1200 ute
pm sent.
Posted on: 2011/6/3 12:02
Hey mate could you give me a call. I have sent my number. Could have a look this weekend if possible? Cheers
Posted on: 2011/6/4 2:31
From ipswich
engine is stil for sale
could ppl please stop wasting my time, serious buyers only
Posted on: 2011/6/20 5:31
datsun 1200 ute
Sone decent photo's of the manifolds would be nice.
Posted on: 2011/6/20 10:30
