Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Best non boosted master cylinder
cracka50
Posted on: 2011/6/2 21:27
Hello i now have all the bits to do s13 front brake swap
and bluebird rear disks. Just wondering, non boosted what would be the best cylinder to go with this setup? Thanks adam
#2
Re: Best non boosted master cylinder
grant76
Posted on: 2011/6/2 22:03
standard 1200 disk/drum master cylinder works fine on the 2x s13 swaps i've done, with the rear disks as well maybe 120y/180b
#3
up2mischief
Posted on: 2011/6/3 5:26
what struts are you using and what diff you got?
#4
cracka50
Posted on: 2011/6/3 8:17
1200 disk struts and h165 diff.
#5
ANGE
Posted on: 2011/6/3 8:49
its personal preference, i run a standard bore master cyl on mine. i like a bit of pedal travel with an unboosted setup.
#6
cracka50
Posted on: 2011/6/3 11:11
Benny once told me the larger bore gives more travel ( hope i got that right)
is this the only difference?
#7
ANGE
Posted on: 2011/6/4 0:49
larger bore will give less travel.
my advice would be to carry out the brake upgrade and see how you like it. if you find your pedal travels too far for your liking then upgrade the master cyl to a larger bore to limit the pedal travel.
#8
benny
Posted on: 2011/6/4 1:03
Spot on.... With different bore size master cylinders not only will the pedal travel change, but also the effort required. I run a S13 [250mm rotor size] front brake setup on my sedan with a 7/8ths MC. It works fine but the effort required is too hard for my liking. The std MC [11/16ths or 13/16ths, cant remember] was too soft for my liking, so a 3/4 MC from a p510 may be just the ticket. You can view topic.
