Best non boosted master cylinder
From Sydney
Hello i now have all the bits to do s13 front brake swap
and bluebird rear disks.
Just wondering, non boosted what would be the best cylinder to go with this setup?
Thanks
adam
Posted on: 2011/6/2 21:27
Re: Best non boosted master cylinder
From New Zealand
standard 1200 disk/drum master cylinder works fine on the 2x s13 swaps i've done, with the rear disks as well maybe 120y/180b
Posted on: 2011/6/2 22:03
Edited by grant76 on 2011/6/3 7:01:52
what struts are you using and what diff you got?
Posted on: 2011/6/3 5:26
From Sydney
1200 disk struts and h165 diff.
Posted on: 2011/6/3 8:17
From Melbourne AUS
its personal preference, i run a standard bore master cyl on mine. i like a bit of pedal travel with an unboosted setup.
Posted on: 2011/6/3 8:49
1973 B110 A12
From Sydney
Benny once told me the larger bore gives more travel ( hope i got that right)
is this the only difference?
Posted on: 2011/6/3 11:11
From Melbourne AUS
larger bore will give less travel.
my advice would be to carry out the brake upgrade and see how you like it.
if you find your pedal travels too far for your liking then upgrade the master cyl
to a larger bore to limit the pedal travel.
Posted on: 2011/6/4 0:49
1973 B110 A12
From Sydney
Spot on.... With different bore size master cylinders not only will the pedal travel change, but also the effort required. I run a S13 [250mm rotor size] front brake setup on my sedan with a 7/8ths MC. It works fine but the effort required is too hard for my liking. The std MC [11/16ths or 13/16ths, cant remember] was too soft for my liking, so a 3/4 MC from a p510 may be just the ticket.
Posted on: 2011/6/4 1:03
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
