Browsing this Thread:
1 Anonymous Users
Re: Weber, Dellorto, Mikuni Rebuild Service- Good Prices! |
From Sydney
Quote: clyons8 wrote: Well there you go! Cheers benny I hadn't ever heard of these.
Regarding the pump springs are these the springs that sit behind the facet pump diaphragm? or the springs that sit within the pump-rod/piston?
They are the springs that sit inside the pump rod /piston assembly for Weber. For dellorto it would be the spring under the diaphragm. Weber and dellorto have evolutions of there progression holes. e.g 45 dcoe 13's are different to 45 dcoe 52's or 52G's for that matter
Posted on: 2011/6/4 3:00
 ----------------------------------------- 1971 B110 Sedan GX Spec 1970 KB110 Coupe Track Car 1970 KB10 Coupe ----------------------------------------- S13 caliper b...
From Seattle ,WA.
Quote: I'm confused, are you talking about the plug in the picture below? If so these are the later type of Weber where the aux venturi sleeve and choke collar are secured via the small lugs and ram tubes that bolt to the front of the carburetor. thats what I was referring to - if they'd been a plug into the venturi chamber I'd think one could use it for a vac advance port. My DCOE only has the plugs in it so I was curious. I guess the newer DCOE's actually have a vac port on them somewhere for that purpose. here's a pic of the accel pump in my DCOE - you can see the spring under the brass cap that benny is referring to..
Posted on: 2011/6/6 16:51
Almost, but no, under that cap in your fingers is a small weight which assists to serve the ball valve (small ball bearing).
The spring benny is talking about is just visible beneath the pump rod retaining plate (to the right of the cap that you are holding).
Your other option is to plumb the vacuum feed from the manifold.
Posted on: 2011/6/6 18:00
From Seattle ,WA.
my lack of clarity - the pic was meant to show the accel pump to the right of my giant finger - that just happened to be the closest pic I had which was to remind me where the ball went always good to have pic's for reassembly & I used em too!
Posted on: 2011/6/6 23:48
From Sydney
Clyons work all fitted up, just gotta tune them now.
Posted on: 2011/6/7 8:43
From adelaide hills
pm'd chris
free bump :)
Posted on: 2011/6/10 7:14
1977 1200 ute aka franky weekender 1979 sunny wagon aka rod the second daily
Hey Rhys,
Sorry I sent you a text but it never sent. With the dellorto you can just email me some pics if you want.
Chris
Posted on: 2011/6/13 5:37
Hello,
Just about to finish a set for another member (sorry for the huge wait). They have come up awesome and I'll get some pictures up during the week.
Really keen to do some more sets for people if they're looking have their carbs rebuilt.
Send me a PM!
Posted on: 2011/10/22 12:11
From mandurah
Cracka50 where did you get your filters how much and what are they called
Ive got socks but they dont fit very well and choke the motor
Engine and carbs look mint ,nice work !
Chris does an awesome job ,and does it for a good price!
Cheers
Posted on: 2011/10/22 13:44
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
Piper Cross and ITG both make those filters (there are a few others also).
Posted on: 2011/10/22 17:46
