78 280z...no 5th gear...Help!!
From South Dakota USA/Trinidad and Tobago
My cousin just got a 78 280z 2+2 and it wont go into 5th gear. All the other gears including reverse goes in fine but no 5th. Anyone know what this could be and how to fix it??
Posted on: 2011/6/12 4:41
3NE 2NR
Re: 78 280z...no 5th gear...Help!!
From Perth WA AUS
I have a dodgy method that MIGHT fix it for a while but I strongly recommend you get it checked out first.
Posted on: 2011/6/12 13:17
Datsun 1200 2Dr sedan.
From mandurah
maybe its only a 4 speed??? or didnt they do a 4 speed in the 280Zs ?
Posted on: 2011/6/12 13:59
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
In the US 280zs came with both 4 and 5 speed manual. It did go into 5th when I first drove it. My cousin just got the car for $1500...its been sitting since 03 so it needs a little work...but it runs good.
Could itbe the shift fork or linkage thats stuck or something?
jpg  0518111716a.jpg (100.38 KB)
4889_4df4ff1b95d23.jpg 640X480 px
Posted on: 2011/6/12 19:03
3NE 2NR
Top-up/Change the oil.
I meant transmission oil. I had a GB that was missing second and third was hesitant, put some penrite 75 trans oil in and both gears came back. Oil was low and very old/dirty.
Posted on: 2011/6/13 1:54
i'll try that...hopefully that will work
Posted on: 2011/6/13 3:44
3NE 2NR
Maybe just dump the oil first and actually measure how much comes out, then you know it's either low or just right. By then you can see if the oil is filthy and gritty and if it is then hopefully some fresh decent oil will help things along. May have to do a couple of changes before you iron out all the issues.
Having said that it would probably be something a little more serious but fresh oil won't hurt.
Posted on: 2011/6/13 3:51
how do i check the linkage in the tranny?
Posted on: 2011/6/13 6:29
3NE 2NR
Bent internal linkage can cause this.
Or they swapped the 5 out between test drive and purchase.
Posted on: 2011/6/14 0:49
I remember testing the tranny out to see if it went into all the gears and they all went in just fine. It's just weird but I just hope it ain't anything major.
Posted on: 2011/6/14 4:18
3NE 2NR
