rust repairs stainless
hey guys just wondering why when i see alot of rust repairs done why people dont weld in stainless sheetmetal instead of mild steel? would last alot longer
Posted on: 2011/6/17 8:45
Re: rust repairs stainless
From Melbourne, Australia
You can weld mild steel and stainless together but I believe the two different metals react with each other and cause corrosion between the join. Same if you say put a stainless washer against raw steel.
You could make the whole car out of stainless and avoid the problem!
Stainless is also heavier as it is denser than mild steel.
I'd like to see a fully polished stainless Datto, very nice!
Posted on: 2011/6/17 9:09
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
im not to sure about that one mate i know what you mean but if its primed properly why wouldnt it last longer if your only replacing little square sections at a time
Posted on: 2011/6/17 9:13
datsun a15 ute
From Adelaide
The weld zone will be chrome depleated and as shoota said the dissimilar metals is an issue. No worries if it's painted but once the two metals are exposed you have a galvanic cell and accelerated corrosion. It's to do with the galvanic series of metals more reactive metals essentially sacrifice themselves for the less reactive (sacrificial anode). The same reason alloy heads corrode against the block.
Posted on: 2011/6/17 9:54
From Near Bundaberg QLD
Yes, the stainless eats away the mild steel it is attached to, there was an old steel tank at work which the stainless steel patches fell off, the welds were still intact and the wall thinckness was fine everywhere except for the 2 inches surrounding where the patches were sitting.
Posted on: 2011/6/17 10:05
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
From newcastle nsw
it doesnt matter wat steel u use any repair will rust eather side of weld...
Posted on: 2011/6/17 14:55
Stainless will corrode the surrounding mild steel quicker than any other metal, painted or not.
Posted on: 2011/6/22 14:53
From Geelong, Vic
apart from the galvanic effect. isnt it just kinda pointless to weld in stainless with the aim of having the patch last longer? no point having a completely rusted out datsun with a couple of mint square patches in it
sure if you were somehow making a whole panel out of it there might be some point
the galvanic effect isnt an issue if both sides of the metal are painted...as then there should be corrosion of either metal. just like a rust repair should rust again if it is properly painted, which is usually the issue with patches that you cant get to the back of to paint
Posted on: 2011/6/23 2:00
a deloreon with a flux compacitor.....no rust problems at all....hah.
Posted on: 2011/6/23 2:44
From Sydney, NSW, 2036
it's difficult enough trying to work zinc anneal over cold rolled... stainless is way too hard and way too expensive.
Posted on: 2011/6/23 3:50
81 Datsun ute
