a15 flat top pistons question
From Vanderbijlpark, South Africa
hi all, i'm busy with my a15, got it bored out 60 thou (1.50) mazda e5 pistons with modified gudging pins to match. must get the block decked and was wondering if i should deck the pistons to flat top as well, question is if the pistons will work flat top or is going to need a valve relieve in the pistons? any advice please? i'm using an h75 head which is match ported to twin su manifold, 2mm shaved off the head.
Posted on: 2011/6/24 8:12
93' Nissan 1400 a15 60a (daily)
82' Datsun 1400 ute (sold)
73' Datsun 1200gx Coupe (sold)
Re: a15 flat top pistons question
From Freo
would depend on the lift of your cam,
you'll need to assemble it and measure the clearance anyway...
Posted on: 2011/6/24 8:14
A15 PSI Project Motor
'72 CB750k,
i'm using the standard a14 bottom end atm with standard pistons. cam is a tr68 290 degree duration, 11.5mm valve lift
Posted on: 2011/6/24 8:23
From mandurah
With 2mm off the head and flat tops at 0 deck height ,with that cam ,ide say yes get the fly cut
What's the ccs of the head ? And how far down the bore will the Mazda pistons sit at tdc ?
Posted on: 2011/6/24 9:00
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
the pistons atm looks alot like normal a14 pistons with a small dish, at tdc the pistons is 1.5mm from the top of the block
Posted on: 2011/6/24 9:15
From sydney.nsw
what made you use mazda e5 pistons. e3 is a full flat top with a +0.76mm dome in centre. what comp are you chasing.taking 1.5mm off deck is alot to take off + 2mm off head(pushrod adjustment maybe a problem). cheers
jess you are learning well(for a bright sparky)HAHA.
Posted on: 2011/6/24 9:38
Edited by bige on 2011/6/24 10:03:42
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
A15 and A14 use different pistons, though both are the same diameter. If you make the Mazda pistons work with the A14, then they won't be right for the A15.
Mazda pistons give the A15 some zoom-zoom.
Posted on: 2011/6/25 3:24
the a14 bottom end is standard in the ute atm, i'm using new pistons for the a15. i bought the a15 with mazda pistons fitted already as it was used fr turbo but one piston was damaged. had to put bigger pistons and mazda was the best option at this stage as the conrods was already modifed for it. i took it in saturday to get the block decked with the pistons but it will not be flat top pistons as the e5 pistons has a pop up centre and will only be milled to where the centre of the pistons is fluch with the deck.
Posted on: 2011/6/27 8:21
So your A14 was fitted with A15 pistons that were machined to work with an A14?
Posted on: 2011/6/27 22:33
