Browsing this Thread:
1 Anonymous Users
a couple of 5 speed questions |
From cold toast
so as im sure you guys have worked out, i have a 5 speed gear box, im 90% sure its a 60a, but not certain. today i bolted it upto an a12 we have here at home and dropped the engine into the engine bay and checked out clearances for everything. it looks as if the gearbox cross member mounts on the box are in the same place as the ones on the trans tunnel, i thought this was odd as ive always seen the mounts having to be extended to match, also, the shifter hole in the tunnel doesnt match up either. now this is an auto chassis, so im not sure if that is why i have had this problem, ive looked through the wiki and i cant find an exact answer, have i done something wrong or is this a what is expected? im hoping someone can shed some light, as im stumped, oh and its a 71 1200 sedan thanks guys
Posted on: 2011/6/26 12:44
Re: a couple of 5 speed questions |
From Fremantle, West Australia
If its a smooth case with "60" stamped on it it will be a FS5W60A with the drain plug pointing down or FS5W60L with the drain plug pointing backwards or parralel to the box
if the rear mounts match the auto tunnel mounts , that is a bonus if the shifter hole is different, that is a bugger
how is the clearance for the reverse switch??
Posted on: 2011/6/26 15:55
From Seattle ,WA.
you sure it s a 5 spd.? post a pic...
Posted on: 2011/6/26 16:49
Registered Users Contentmaster Usermaster
If the mounts line up, it's probably a 4-speed. Look for this mark on the transmission case:  The series casting mark is on the right side of the gearbox.
Posted on: 2011/6/27 2:27
From Melbourne, Australia
5 speed mounts do line up with Auto mounts... so that is correct
shifter hole should line up too though.... so that is weird
Auto mounts on the car are roughly 6 inches further back than on manual cars The shifter hole is slightly different (square on auto with 4 captive nuts for shifter, round for manual with no mountings). but it's in the same place
Posted on: 2011/6/27 5:05
From cold toast
yeah its definatley 5 speed, im not too sure what the go is with the shifter not in the same place! argh! ill have another look today, maybe i just did something wrong... hmmm oh and ill check weather its an A or L box too. thanks for the help. oh and is there any ideas as to what i may have done wrong to not get the proper alignment ?
Posted on: 2011/6/27 8:04
What is the alignment problem that you are referring to? The shifter not lining up with the automatic transmission shifter hole?
Posted on: 2011/6/27 8:11
From cold toast
yep, just wondering if it should line up, cus if it doesnt then i guess ive done something wrong!
Posted on: 2011/6/27 8:44
From NZ
Shifter hole 'adjustment' sounds like an easier fix than fabricating mounts. Tin snips or jigsaw perhaps..
Posted on: 2011/6/27 11:23
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box. Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From cold toast
yes thats what i was planning, but i dont want to cut it up if i have done something wrong and wont have to cut it anyway... same principal as measure twice cut once. i dont wanna have to make an abortion of a trans tunnel haha
Posted on: 2011/6/27 11:59
