(1) 2 3 »
1200 ute now 2 b l18 instead of l20b
From Innisfail nth queensland
i can get a cheap crossmember 2 suit a l18 so iv decided to scrap the l20b idea can any1 let me know what i can use off the l20b 2 upgrade the power of th l18 in tend on getting the l18 rebuilt b4 fitting and fitting a set of twin carbs and cam any ideas on what if any i can use off the l20b they r both 82 model engines
Posted on: 2011/7/5 13:51
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: 1200 ute now 2 b l18 instead of l20b
Grab elec dizzy for sure. If the heads good keep it.
Posted on: 2011/7/5 14:05
Have your l18 block mains line bored to fit the L20B crank
Bore to 87mm for Z22E pistons (get pistons tops milled .45 mm)
Use L24 conrods shot peened prepped
Your deck clearance will be 0.100mm just perfect like L16 comp.
Youll have 2045cc with 1.547 rod stroke ratio which
will be awesome down low to 7000rpm.
Head options are plenty depends what you want and can
engineer with your ride.
Posted on: 2011/7/5 16:18
From Malaysia
thanks, awesome info D. will take note. a good option for my 1600.
Posted on: 2011/7/5 17:29
Or use an l16 block with l18 crank with 240k pidtons and it effectively gives you an l17... Can't remember the rest. Super piggy where are you
Posted on: 2011/7/5 22:27
The L18 and L20B use the same crossmember. Just use a suitable oil pan to match (Front, rear or mid-sump).
Posted on: 2011/7/5 22:35
But depending on the mounts, it may sit higher in the engine bay meaning that 20mm of l20 hits the bonnet possibly, making the l16 or l18 an easier install
Posted on: 2011/7/5 22:42
It won't hit the bonnet in a 1200.
Posted on: 2011/7/5 23:02
From Geelong, Vic
like dd said, they are the same mount, Unless the crossmember was made by a blind retard then the L20b will still fit. you will just have to run sidedraught carbies i would imagine as its only the filter housing that hits the bonnet in my experience
Posted on: 2011/7/6 0:14
From Malaysia
L16 and L13 use the same block isn't it? i want to 'cheat' the road tax by using L13 block.
(1) 2 3 »
