« 1 (2) 3 »
Re: 1200 ute now 2 b l18 instead of l20b
From Geelong, Vic
pretty sure L13 L14 L16 and L18 are the same block with different bores and strokes
Posted on: 2011/7/6 0:34
From gold coast aus
l20b block is inch higher to allow for longer stroke
if you look at timing cover is extra bolt compared to l18
Posted on: 2011/7/6 2:35
As Nick said with 20mm taller l20b youll need sidedrafts but
the L13/14/16/18 are better fit and with L20b crank will give
a serious stroker. Bakat in your case if you can get the any
L13/14/16 then you can use the l18 crank straight in.
if you bore the L13/14/16 bore of 83mm to 85mm & use the L18
crank you get an L18. Plenty of meat for this.
Which is more avail your way the L13,L14 or L16?
I prefer the L16 sleeved to 87mm and use the L20b crank if
for my datsun 1000 as Im limited to 1.6 for turbo.
Posted on: 2011/7/6 2:50
From Malaysia
i got an l13 and an l16. my l16 was freshly built.
l14 is rare here, same with l13. l16 is plenty (we got PA10 SSS and 510 SSS here). i know i can just put an l18. but i want to use the l13 block because of the rules and regulations and remember what i said earlier? anything above 1.8 will kill you (pricey roadtax lol).
Posted on: 2011/7/6 3:24
Thats cool you guys got the L13!
Try this calculator if you dont know of it yet youll like it.
http://www.ozdat.com/ozdatonline/enginedesign/
L13 with L18 crank, rods and 85 bores is all you need
to stick it up those beaurocratic capitalist A-wipes!
L16 fresh is a nice Jigga!
Posted on: 2011/7/6 7:08
From Malaysia
lol. i dunno such application exists! would take some time to play around...
Posted on: 2011/7/6 7:42
From Malaysia
i have to use this 83.5mm piston as i cant find any oversized 'standard' piston for my L16. now that i know the L13 can be bored and stroked, i just have to find a smokey L18 for cheap. the head is W53 though, port matched to the twin hitachi.
Posted on: 2011/7/6 7:50
Id just stick with the l16 since its reco.
You could build the L18 on the side if you
find an L18 engine.
Posted on: 2011/7/7 11:33
From Malaysia
we got plenty of 910 and 180k (c210) here. no problem finding L18.
Posted on: 2011/7/7 11:47
You also have plenty of A series 5 speeds!!!
Posted on: 2011/7/8 2:23
« 1 (2) 3 »
