(1) 2 3 »
Gated shifter base for a 70 series box
I wonder if its possible to make a gated
ferrari like shift base as in this pic for a
stumpy or other 70 series boxes?
jpg  gated.jpg (13.37 KB)
737_4e1c1a84b14ed.jpg 205X270 px
Posted on: 2011/7/12 10:57
Re: Gated shifter base for a 70 series box
Yes, but the gaps would have to be 50mm wide to accomodate the slop in the shifter!!!
Posted on: 2011/7/12 12:13
hahahaha cant compare the big F boxes
How about a Getrag box? I wont mention
the T5 as youd probably say 49mm for that
Posted on: 2011/7/12 12:41
From mandurah
What for though ,the standard boxes go in ok
Most of the time hahahaha
So would it just be a guide plate that would bolt to the box ?
Posted on: 2011/7/12 16:28
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Malaysia
its for wow factor isn't it? cool!
Posted on: 2011/7/13 0:22
From Perth WA AUS
Should be no problem to make, just time consuming to make a template then its all go!
Posted on: 2011/7/13 8:51
Datsun 1200 2Dr sedan.
put my name down for 1 Levey
Posted on: 2011/7/13 9:20
From Perth WA AUS
Right now I really dont have the time to make them, but I'm interested and I'll see what I can do.
Good idea D, I'd thought about this years ago but never got around to it then I forgot about it :)
Posted on: 2011/7/13 11:57
Itll be good for a 71c box that sr, ca,qr and rb people use
we are just the sloppy 71B crowd.
Levs have you thought of a clear rocker cover for the A series
like your tailights *:)) just muckin round
Posted on: 2011/7/13 14:00
From Perth WA AUS
Holy crap D,
I am a timber flooring installer!
And would need the required gearboxes fitted to make a template anyway :)
Are you getting slack? cause I know you could do this yourself!
Clear rocker cover would be nice... But beyond my budget and skills, $30,000 would get a mold done and then the covers would only cost about $20 each.
It would be nice though:)
Posted on: 2011/7/13 14:30
(1) 2 3 »
