A series quad throttle body EFI setup for sale
From Rosewood, QLD
http://datsun1200.com/modules/myalbum ... &com_order=1#comment69420
as you can see its wicked, still sitting in box it arrived in from rally1200, need to sell as im selling everything, for the tidy sum of $1070 (exactly what i paid) i will post anywhere in OZ. PM or txt 0409 444 626.
Posted on: 2011/7/21 8:19
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: A series quad throttle body EFI setup for sale
From Coondle, WA Australia
that setup really is porn!
I would love to justify to spend the cash...
Reckon you could put an air box on it and use a turbo with it?
Posted on: 2011/7/21 10:19
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Tasmania
Now that is just pure porn!!!! If i wasnt getting my carbs rebuilt I would seriously think about buying these.
Posted on: 2011/7/21 10:58
Proud member of " The Tasmanian Datsun Owners Group"
Very strict race application those things, to make things (remotely!) relevant you would need to run a pair of 45mm side draught carbs and remove the sleeve chokes altogether.
Troy, you can. The carbs have only been dismantled, nothing has started yet.
As a comparison, your dellortoes have 30mm chokes in them.....
Posted on: 2011/7/21 11:02
From Ringwood, Melbourne, AUS
I agree they aren't for a small bore engine but they won't be that bad on 1500+ CC.
Don't forget carb chokes are mainly there to speed up the airflow and draw fuel from the jets, when that fuel is being squirted into the chamber in a finely atomised spray by an injector, it isn't quite so important..
Posted on: 2011/7/21 11:26
Deano
From Tasmania
Keep rebuilding Chris. got some 32mm chokes coming for them. I cant afford the Efi right now. would love to have it as a spare for the future though.
Posted on: 2011/7/21 13:16
From Rosewood, QLD
they were running on an A12 with A14 crank, would suit worked A14-A15 well as i had planned but now everything has to go.
Posted on: 2011/7/21 19:58
From Rosewood, QLD
bump
Posted on: 2011/7/22 11:42
From Rosewood, QLD
will swap for SR20 gear
Posted on: 2011/7/23 5:28
From adelaide hills
whats the advantage of running an A14 crank in an A12??
Posted on: 2011/7/24 10:03
