Need longer studs
From adelaide hills
what studs can i run in 120y struts that are longer than standard? ? ? ?
Posted on: 2011/7/21 9:30
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: Need longer studs
Try R31 Skyline studs they are a bit longer and thats what I've used on 120y struts for my S13 brake conversion.
Posted on: 2011/7/21 9:34
From adelaide hills
so they are same spline?
Posted on: 2011/7/21 9:36
From vic
if studs are to small for rims get new nuts that extend out thats what i use on my 120y with jellybean rims!
Posted on: 2011/7/21 9:54
Yep, just knock the old ones out and tap in the longer R31's in and your set! easy.
Posted on: 2011/7/21 11:26
From Melbourne AUS
s13 silvia and 180sx are also the same but longer
Posted on: 2011/7/21 12:10
1973 B110 A12
From sunshine coast
When I was doing my s13 120y set up I used landcruser studs ....way long but pressed right in and the tread is the same as the standard studs .
Posted on: 2011/7/21 12:40
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From vic
must of been from 80 series 6 stud yer?
100 series is 5 stud and they use fatter studs dont think they will fit!
Posted on: 2011/7/21 12:46
From sunshine coast
Probs :P got my mate at autobarn to get them for me same thread and spine as the standard studs :)
Posted on: 2011/7/21 12:51
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From RAdelaide
Try this Long stud listing
Should also be able to find length, knurl size etc etc on that site
Nice wheel products
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
