gearbox weight
Not too shy to talk
From canberra
outta curiosity what would a 4 speed a series box weigh. I know their light but does anyone have an exact figure?
Posted on: 2004/2/16 8:21
Re: gearbox weight
Not a direct answer, but the FS5W60a 5-speed weighs 65 lbs about half-full of gear oil. I know cause I'm getting one ready for shipping.
There are three common 4-speeds, the 56-series (original 1200 issue) and two different B210/B310 4-speeds.
Posted on: 2004/2/16 8:50
Re: gearbox weight
Not too shy to talk
From canberra
yeah i need to know the weight for freight aswell.
Posted on: 2004/2/16 11:22
Re: gearbox weight
From Brisbane, Australia
according to my scales, 19kg dry with mount and x-member.
Posted on: 2004/2/16 22:43
Re: gearbox weight
Which 4-speed gearbox did you weigh?
Posted on: 2004/2/17 3:10
Re: gearbox weight
I'm not up on all the codes on these boxes, but it was a standard 1973 1200 sedan 4 spd box.
Posted on: 2004/2/17 3:30
Re: gearbox weight
Hey, that's only 42 pounds (19 kg). A lot lighter than the late B310 5-speed (65 pounds, 29kg with some fluid). No wonder Mario preferred the 4-speed.
Posted on: 2004/2/17 6:23
Re: gearbox weight
Funny that a 300hp capable rx5 is as follows
eg.
Weights, inc bellhousings:
RX-5 - 25kg.
Supra - 35kg (Dellow BH).
Celica - 48kg (Alloy adaptor plate, RX-4 BH).
info from Ausrotary.com
Posted on: 2004/2/17 7:09
Re: gearbox weight
That is fairly impressive ... how does Mazda make the tranny so light and yet so capable?
But not so funny if you realize HP has little to do with tranmission capacity. It's mainly the torque (twisting force) that a tranny has to withstand ... In other words 300hp @ 10,000 rpm results in only half the torque of 300hp @ 5,000 rpm.
Posted on: 2004/2/17 7:21
