FS 120Y, a12 40mm weber + spares. $1300 ONO - SOLD
Quite a regular
From Blue Mountains NSW
120Y was once registered but I was going to race it but have children and no time. It includes a proper half cage (Penrith Muffler Man) not welded in, never been in an accident but removed from a rusty shell.
It runs a 4 speed gearbox, locked diff.
Stanza front struts/calipers. Oil inserts with heavy oil for stiffer rebound.
Reset rear leafs (half extra leaf + reverse rolled eye).
Neg camber strut tops.
Shortened steering arms (faster lock for rally).
Elec fuel pump.
Thermo fan with switch installed in radiator.
Peugeot 205 bucket seats installed.
4 x 14inch mags (2 with flat tires in the boot).
MOTOR: A12 standard bottom end.
Long duration rally cam, not scalloped pistons.
Lightened flywheel
Extractors
single sidraft weber 40mm
OVAL PORT HEAD H89.
recurved distributor for more advance.
Motor runs very well, idles normally and revs out to ......
NEED BRAKE BOOSTER REPAIRED AS IT DOES NOT WORK. Master cylinder works ok.
COMES WITH PARTS:
Spare 4 speed, flywheels, starter motors (2), altenator, guards, some suspension parts.
Rust cut out, you could put interior back in and change diff and get registered fairly easily or transport parts into your project.
Took this in a motorkhana and it went well but had an open diff at the time.
PM for more details or organise a look.
Respray Pics FB
YOUTUBE CLIP PICS.
Posted on: 2011/8/7 12:10
Edited by mountaindat on 2011/8/8 9:41:15
Re: FS 120Y, a12 40mm weber + spares. $1300 ONO
Quite a regular
Comeon, Or Near Offer, what is it worth????
Make a decent offer on the cage or spares if you like.
Posted on: 2011/8/8 8:18
Re: FS 120Y, a12 40mm weber + spares. $1300 ONO - SOLD
From mandurah
sounds like a good little car .looks good too ,got some pretty good mods too ,whats the go with the leafs ,have you got any pics of how you did the flipped eye thing ? is that just the main leaf flipped over ??
good luck with the sale
Posted on: 2011/8/8 10:25
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Quite a regular
I cut half the top leaf off and bent it back the other way, cold bend using some chains and a hydraulic jack. I have done this a few times and it works great for the dirt cars as they are not too stiff and you tend to keep rear wheels on the ground. Just cut the eye off the original and add the extra part.
Got this advice from a well respected datsun suspension specialist so it is not a BS mod!
Hope that helps.
Posted on: 2011/8/10 0:07
