Radiator - 1200 CA18DE Auto
From MOOROODUC. Victoria
I have decided that my EXA radiator is not going to do the job.
First it's not an Auto radiator,
Second it has the outlet on the passenger side
Third it has side tanks - need top and bottom
So I am after one that will fit the same
690mm x 385mm x 37mm
and have a goose-neck as a filler (so the tank can totally fit under the front) ... The CA is well forward(75mm from the firewall) so I could use the g/box mounts on the tunnel
I know I don't want much but before I go look for a custom job I thought that I would ask
here's a pic from my build as to where I am putting it
gif  Radiator in place 1.gif (169.64 KB)
8710_4e51baa3e3982.gif 640X480 px
Posted on: 2011/8/22 3:10
Re: Radiator - 1200 CA18DE Auto
Exa rad is similar to ca rad size so might get a stock ca auto rad in there. I'm using stock ca manual rad and I didn't mod front as much as yours
Posted on: 2011/8/22 3:23
by 'ca' do you mean Silvia? .. and will it have a goose neck filler so I can tuck the whole radiator under the support i built?
Posted on: 2011/8/22 3:33
just Rang a radiator guy and he recommended moving the bottom hole over to the drivers side and putting a baffle in the middle of the radiator to make the coolant go over the other side and back (approx $120 to modify the EXA one). As for the Auto fluid - get an aftermarket cooler (and find space for it)
Posted on: 2011/8/22 3:58
S13. Nah had filler in top tank.middle of core
Posted on: 2011/8/22 3:59
From Melbourne, Australia
yeah i would get your hands on an auto one, then modify it
radiator guys have a catalogue full of all radiators and their dimensions, so if you head to one you could browse for something else
if you have the top outlet on the passenger side its quite easy to make that work with a CA, but if its the bottom one that would be not so good, that really needs to be on drivers side
Posted on: 2011/8/22 5:01
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
bottom is on the passenger side which would mean a pipe under the harmonic balancer .... not gonna happen
Posted on: 2011/8/22 5:55
From hastings,vic
got a rad book with all the sizes dave
come have a look.
Posted on: 2011/8/22 6:11
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
I ended up taking the EXA radiator to get modified ... move the bottom hole over to the right hand side and put a baffle in the middle to force coolant across the core.
The Radiator place called me yesterday with bad news ... they said that the core needed replacing and that the job was now going to cost $450 rather than $150.
so the radiator is in the bin and the search continues
Posted on: 2011/8/27 0:02
Ca 18 det auto will do it
Posted on: 2011/8/27 1:32
