H89 water gallery pluging?
From Gawler, Sth Aust
Im tryin to fing some info on gallery plugging in the h89 head. Ive read in old threads that people have plugged water galleries to the manifold to save the hassle of a wet inlet manifold.
How much can be drilled out in order to tap a thread?
Where do can i buy these screws?
Another suggestion I was given was to use a plumbing filler, even though its heat resistant and strong enough to be tapped, plugging sound safer.
Any input would be great.
cheers
Posted on: 2011/8/24 11:10
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: H89 water gallery pluging?
If your manifold comes down over the water ports, you don't have to plug the water holes. You can just bolt it up.
I removed the old gasket, and saw the water holes. It had not leaked.
When I fitted a new gasket, it was a wet type. I used RTV silicone sealer. Works a treat. After fitting the intake/exhaust gasket, before fitting the intake manifold put a button of goo in the water ports, let it tack up slightly before fitting the intake.
Posted on: 2011/8/24 11:57
From Adelaide
You can buy grub screws in many places, most auto shops for example. Measure the hole, tap the mext mm up and screw in a plug. A bit of form-a-gasket or something to seal the thread would help prevent corrosion. DD's method will also work.
Posted on: 2011/8/24 13:01
When I removed the manifold later, it seems it sealed quite well
easy way to seal it, but coolant leaks out when you pull the manifold, except one stayed in. Maybe put some grease on the intake, will keep it from pulling the plugs out.
Posted on: 2011/8/24 19:51
From Las Vegas USA
In the motorsports catalog there used to listed a stud and plug kit..............it was for fitting side draughts, you simply tapped the head and put in the flush mount plugs. The plugs are 10 mm x 6 mm deep (I think) socket head.
Tom
Posted on: 2011/8/25 2:47
Found it in my 1984 Nissan Competition catalog:
99996-H1140 INTAKE MANIFOLD
99996-H1149 STUD & PLUG KIT Required when installing 99996-H1140
No photo but your description is clear.
Posted on: 2011/8/25 5:00
From Kuala Lumpur, Malaysia
Posted on: 2011/8/25 10:30
Face Your Demons
Thanks guys this stuff really helped, ill have to hit the stores and track down some grub screws of a similiar size. knowing that its a process nissan suggests gives me piece of mind. I was worried about opening the hole a bit and cutting into something i shouldnt.
Posted on: 2011/8/26 7:57
72 B110 A14
06 380 VRX
Will plugging these holes increase engine performance? My A15 head is not plugged at the moment.
Posted on: 2011/8/26 9:26
From Freo
from memory 4mm (mabee 5mm) tap and screw some plugs in there, i just got bolts cut off the heads slotted them and screwed them in.. with a bit of loctite pipe sealenat on them of course..
Posted on: 2011/8/26 9:48
A15 PSI Project Motor
'72 CB750k,
