Changing head gasket on ca18det
From Sydney
Hey guys is it possible to change the head gasket while it's still in the engine bay? How hard of a job is this?
Posted on: 2011/9/8 4:00
Re: Changing head gasket on ca18det
It's an in line 4- head gasket on top why would you remove it????
Posted on: 2011/9/8 4:26
From Melbourne,Australia
Yeah no need to pull the motor out mate
Posted on: 2011/9/8 5:50
From Sydney
it would be easy removing the turbo manifold n intake,do you have to remove the timing chain?
Posted on: 2011/9/8 10:10
From MOOROODUC. Victoria
has the timing Belt been replaced in living memory?
It's not an expensive item and u will have to remove the camshaft gears so if you have the radiator out then it can be done thru the front.
I have had good success with lifting the car up and dropping out the engine, g/box, cross-member , etc (remember to disconnect the steering bar under the engine)
Posted on: 2011/9/8 10:31
From Sydney
Would not know if the belts been changed, prob needs a new one so I will get a new one, going from under the car seems to be a good way of getting it in n out,
I have the motor in atm no gearbox cause the clutch n fly needed replacing n machining, when clutch is installed I will put on the box meeting the two half way...
Posted on: 2011/9/8 22:49
