rear end rebuild
From Goulburn NSW
Hi guys and girls is 15k to xspensive to do the following,un pick the rear tray and chassie rails ,move the chassie rails in 2" either side put in new tray tub it, fit a borgwarner diff.Also buy the rear wheels (convo pro hopefully 8.5") fit the fuel cell relocate the battery so when i get it painted the battery mount can be cut out to make room for the ca18,is it near the wright price.
Posted on: 2011/9/8 7:37
Re: rear end rebuild
From windsor, sydney
do you plan to road register it?
Posted on: 2011/9/8 7:42
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Goulburn NSW
HI wards yes i am,im putting the original chassie rails back in to keep it looking original as possible.
Posted on: 2011/9/8 7:45
From Goulburn NSW
anyone?
Posted on: 2011/9/9 4:08
From Canberra
Have you gone to any other places to get quotes to compare? That's the first step I would take if I wanted to know if the place you got the quote from was unreasonably high.
If it is one of the top fab places they will probably be charging more than a guy who does it on the side.
There is a fair bit of labour in doing what you want. From what I've read on other sites to get a vehicle tubbed is usually around $10k from a shop drive in, drive out.
Posted on: 2011/9/9 6:39
YLD.18L
All you can do is what Lachie suggested and get more quotes. Just ensuring your not using backyardbilly to do such a task.
My 1200 coupe dragcar chassis setup is far more extensive and cost around that mark including convos and MT slicks.
Posted on: 2011/9/9 8:28
Sometimes you can get better prices sending your car interstate. John Traverna Jnr is a Legend in the northern suburbs of Melbourne. Reasonably priced and does brilliant work.
BTW. if going for a stock look is your thing, maybe tubs isn't the way to go? Surely it would be cheaper to use a off the shelf chassis kit tailered to suit your needs.
Posted on: 2011/9/9 9:21
first piece of frendly advice , get a engineer onboard NOW! , if you move the rails in you will have trouble registering it , it all comes down to if the engineer will pass it , and dont say "what engineer" when you get pulled over by a "know it all" RTA inspector or police officer they will red card you in a heartbeat . Then that 15K will sting even more.
Posted on: 2011/9/10 13:02
WARDMAN ENGINEERING
CNC machining
0413 595 627
