catch can oil return line
From sydney nsw
hi,
anyone tried to connect a t- piece to the dipstick tube and use it as a catch can rtn line. ??
then,
remove the dipstick, and turn it into a sump breather??
Posted on: 2011/9/18 0:41
Re: catch can oil return line
From Ringwood, Melbourne, AUS
Why do you want to return the oil to the sump?
Just leave it to collect in the catch can and return only the fumes to the intake. Then empty the can when requried.
If you are getting so much oil in the can you need to return it to the sump I think you have bigger problems!
Posted on: 2011/9/18 5:19
Deano
From Malaysia
the oil collected in a catch can should be thick and gummy. no need to return it to oil reservoir, just empty the can when full. yes if you have too much oil there, you have another bigger problem(s).
Posted on: 2011/9/18 5:36
From sydney nsw
its not a street car....
ca's are known for their oil problems, when you rev them beyond 6k for prolonged periods, ie 15min, oil draining from the head doesnt happen quick enough.
The ultimate solution is to add extra drains from the back of the head, but with 3 weeks to the next rally, its not going to happen.
So when you do this , catch cans do fill up, and need to be drained quite offen, so draining back to the sump is ok (oil is changed after each rally 500km)
attached is a pic of what the rb guys do...
Posted on: 2011/9/18 6:17
From sydney nsw
attachment didnt work
Posted on: 2011/9/18 6:18
From sydney nsw
gif  post-23582-1150528192.gif (88.78 KB)
5495_4e757f7a6e7eb.gif 397X298 px
Posted on: 2011/9/18 6:20
From Melbourne, Australia
lol, you didnt mention it was CA
is it turbo? would be better to t-piece the oil return from that, or put a turbo sump on it and use the connection then
adding the dipstick tube as a return line is going to be a very minimal improvement over stock i would think and it would definitely need a breather for any significant amount of oil to be able to run down it
Posted on: 2011/9/18 6:31
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Sorry to change subject but that pic of the rb
seems to have a spacer plate on the block?
Posted on: 2011/9/18 12:44
