Browsing this Thread:
1 Anonymous Users
Re: BRAKES FOR SALE |
From Melbourne, Australia
I just hope they fit under my rims. My 180B struts with RX7 4 spots don't so fingers crossed!
Posted on: 2011/9/21 1:03
Current Fleet- 1996 R33 GT-R Skyline 1996 Falcon XH XR6 Ute 1977 Datsun 1200 Ute A14 (Fergus) 2012 VW Passat TDI Wagon
From hastings,vic
i can fit under 13" steel rims
Posted on: 2011/9/21 1:10
taking up room at home 3 now 2 1200 sedans,3 now 2 1200 coupes,3 now 2 1200 utes 1 1000 wagon,2 s13 silvia's,tranzit tray hzj75 cruzer tray(for sale) and allways changing
Think it's got more to do with offset then diameter For shooter, he's using 17's
Posted on: 2011/9/21 1:27
Thats right Mik. My rims are very flat on the back side so theres not much room for the calipers behind the wheel. Between the inside circumference of the wheel and the caliper there's way too much! I need a set of 355mm discs to fill them nicely.
Posted on: 2011/9/21 2:22
From hastings,vic
big discs u say set up i am working on 335mm disc other disc is std stanza needs a min 17" rim maybe mod the caliper so i get a full wipe on disc they should stop 350z brembo track package discs
Posted on: 2011/9/21 4:06
lol, better get pads that work from 0 degrees, those discs wouldn't get up to high temp going down Mt. Bulla
Posted on: 2011/9/21 4:21
what model hilux are the 4 spots from?
Here I am worried that 250mm vented comho rotors with 180sx calipers are too heavy for a mazda 800 wagon :)
Posted on: 2011/9/21 5:00
That's huge Tommo!! Massive overkill but awesome just for wank factor (and engineering ability of course)!
Posted on: 2011/9/21 5:28
From hastings,vic
10+ for the wank factor these will allso fit on silvia,r31,r32 ect will look good for show on 1200 and fill the rim
Posted on: 2011/9/21 5:32
After a moments hindsight (and before they even arrived in the mail!) I realised the A) I don't need these, B) I can't afford these and C) someone that will actually use them should have them so they're up for sale for what I bought them for!
C'mon, you've all done it before, bought something you don't need!
So, as per Bob's entry on the first page, Hilux 4 spots, cross drilled and slotted rotors, good pads and rebuilt pistons $330 including post.
Cheers.
Posted on: 2011/9/27 4:52
