« 1 (2) 3 »
Re: [VIC] FS - Rebuilt & Worked Oval Port A15, GX Twin Carbs, A60 5 Speed Transmission!
Online
Would you engineer it or club plate it as
2ltr turbo would be over the rules limit?
After seen an A12 do so well recently with
virtually stock internals you could aim for
(82mm->86mm) stroked A15 with e15et rods
custom cast 25.25mm slugs, ball bearing t25g
and good EFI for around 160hp atw @ 6500rpm.
Posted on: 2011/10/21 0:00
Not too shy to talk
From Outer Eastern Suburbs, Melb, Vic
PM Sent
Posted on: 2011/10/21 9:27
It's a 1200 Coupe...and it's white!
From Sydney, NSW
mate i got a Fuel injection set up for an A15 if you want it and want to keep the engine, you just need a ECU for it
Posted on: 2011/10/22 10:33
Snapped crank and still smiling, How do I do it? LOL
You have a PM
Posted on: 2011/10/23 2:52
From SA
Hey mate I have a CA18DET engine if you want to trade. Needs a crank bearing replaced, comes with ball bearing turbo, wiring look, 2x ECU manual and auto, manual box, auto trans, heavy duty clutch, K frame, intercooler. Cheers
Posted on: 2011/10/23 7:57
1200 Coupe ( Rolling shell project not started )
1973 1200 ute ( Soon to be daily driver/ Project)
1997 VW Golf ( Current Daily Driver )
SO it comes with a manual and auto gearbox?
Fix the crank bearing first and then I might think about it.
Posted on: 2011/10/24 2:36
any chance of a ballpark figure you had in mind for the lot??
I'm not saying this as some sort of lame negotiating tactic -- I genuinely have nfi what a ballpark/fair price for it would be, so I'm not sure if I could even come up with an offer that was sufficient, or if it'd be way too low an offer!
Posted on: 2011/10/24 13:13
John McKenzie
ca and srs are awesome but not in 1200s, was cool ten years ago now there like assholes everyone got one.twin carb 4age is cool no hacking of tunnel either.
Posted on: 2011/10/24 22:08
Damn straight!!!
Someone please take the 'giant leap' (more like the little step) of progress and try one of the many alternatives out there.
Posted on: 2011/10/24 22:54
Ruredi, were you looking for an efi setup?
Disco_BOB has these.
Posted on: 2011/10/24 23:27
« 1 (2) 3 »
