63A 5 speed info needed
From NSW South Coast
I need some info on a 63A 5 speed. are they all hyd clutch. If so can they be converted to cable. What tailsharft do i need will a standard one do.
thanks olboy
Posted on: 2004/3/2 1:30
Re: 63A 5 speed info needed
Depending on the donor car, you can generally say that right drive cars had cable operayed clutches, while left drive cars had Hydraulic operation.
This certainly applies to B10 - B110 & B210, models.
Posted on: 2004/3/2 13:43
Love your Datsun.
Treat it well.
From Millgrove Vic OZ
They all start out as hydraulic clutch. I have one that has been converted to cable clutch A cut down stanza tailshaft with a suitable diff flange fitted will do the job.
Posted on: 2004/3/2 21:53
Cheers Feral
thanks feral is the clutch hard to convert is it just a case of using the bits out of another cable type box. Why do I have to use a stanza tailshaft is it the length or the spline or both. Also is the clutch plate the same as a 1200 one.
sorry to be a pain.
Thanks olboy
Posted on: 2004/3/3 3:10
From Christchurch NZ
Speaking of the 63a box, does anyone what cars these were fitted to originally?
Posted on: 2004/3/3 3:52
Forced Induction!
HB211 - Japan-market B210.
Posted on: 2004/3/3 5:03
Fit the bits from the cable box and a small hole in bell housing and drill a cable hole through the bolt up flange. Up Up and away.
Posted on: 2004/3/3 13:17
Cheers Feral
