« 1 ... 9 10 11 (12) 13 14 15 ... 97 »
Re: Super Bee Z24 Mod
From Snohomish, WA USA
Made to the track today but car ran like crap. Its always my luck. Starter went out this morning so I had to run down and get a replacement. Made two horrible passes and loaded the car up. I went home and was trying to figure out what the heck was going and then noticed a needed component. My car runs on two coils. Well runs good on two coils. Runs under powered on one. The 12v leaded to the intake coil was disconnected. So I wasted the last race of the season on some bogus runs.
But now with the better boost I should get it dyno'd. With the Z24 motor I'm only boosting 5 psi. Im redlining at 5000k. My old A15 was redlining at 8500k so I was boosting almost 10psi.
It was a fun day. Watched others pass a few times.
Ski season over so I have to pull the boat tomorrow and winterize. Fun stuff.
Posted on: 2011/10/24 3:11
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
http://www.youtube.com/watch?v=NaaaGnJ8OgA
Ok. Is it as easy as I think? First try at Youtube.
Search for Datsun 1200 SuperBee if link does not work.
Posted on: 2011/10/24 3:54
'73 2 Door Sedan
Responsive!
Posted on: 2011/10/24 9:12
Sorry for the lame video. All I could do at the time. Need someone to video me on the street. Looking for a camera mount for the inside of the car as well.
Posted on: 2011/10/27 5:24
'73 2 Door Sedan
Back to trying to fine tune this beast. When at high Rim's over 5500 the engine sputters and the tach jumps all over the place. I shortened the gap on my plugs to 28 from the stock 35 which helped but not sure if I should gap it more. Spark blowout from supercharger? Timing is set advanced at 15 degrees. Running colder plugs as well. I changed the fuel pressure from 6 psi to 3 psi at iddle and 6 psi at full boost.
Just trying to improve performance.
Posted on: 2011/11/6 23:23
'73 2 Door Sedan
What cam in there? I had spluttering like that with Su, s and LPG- but that was loss of draw signal but occurred when cam lobe ramped up at 4000 rpm.
Posted on: 2011/11/7 0:33
Stock cam. Even with stock cam it shouldn't sputter out. Ill keep messing with it. Thanks for the help.
Posted on: 2011/11/7 0:57
'73 2 Door Sedan
Must be spark and pressure then. But might be some weird ass air flow thing
Posted on: 2011/11/7 1:24
Well the stuttering and sputtering was a clogged fuel filter. Also found out that my car runs the best with spark plugs gapped at .028 and not .035.
Today couple of Bikers on Harley at a gas station asked me to light'n up. I was going sideways before I made it to the street. They caught up with me at the next street light and said that it was pretty impressive. :)
Working on making a video camera mount for my roll bar. Might call tomorrow on getting a dyno scheduled.
Posted on: 2011/11/10 2:39
'73 2 Door Sedan
good to hear its all sorted and look forward to a clip
to add to your original clip years ago.
should have asked the Bikies to light them up too :)
Posted on: 2011/11/10 3:28
